1. AC Question's Avatar
    Can the S7 Edge support dual sim?
    03-28-2016 08:33 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which model number is it? From what I can tell on the web, there is a Duos variant, but the ones that aren't Duos are single-SIM.
    03-28-2016 12:50 PM
  3. dpham00's Avatar
    Correct, there are dual sim models, but all the usa models are single sim.
    B. Diddy likes this.
    03-28-2016 05:47 PM
  4. Gator352's Avatar
    If they are all single, why aren't they on match.com?
    B. Diddy and chanchan05 like this.
    03-28-2016 06:31 PM
  5. B. Diddy's Avatar
    ba-dum-bump
    03-29-2016 01:23 AM
  6. EricReyes's Avatar
    I currently have a Samsung S7 USA Version with 1 SIM
    If I can swap the SIM tray from the Samsung S7 Duos and install it on the S7 USA Version
    Will the phone recognize the two SIM?
    05-30-2016 07:32 PM
  7. chanchan05's Avatar
    Nope. Won't matter if you swap the tray if there aren't any connector pins for the SIM inside the tray port. Or an antenna with dual SIM standby capabilities.
    05-30-2016 08:13 PM
  8. thanhtd_54's Avatar
    yes it support two sim and one external memory card slot
    05-31-2016 05:04 AM
  1. What is a good case for the LG G5?
    By AC Question in forum LG G5
    Last Post: 04-06-2016, 09:31 AM
  2. Where can I purchase an unlocked S7 Edge?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-28-2016, 02:55 PM
  3. How durable is the S7's screen?
    Last Post: 03-28-2016, 01:32 PM
  4. WIll the app drawer on the LG G5 be removable?
    Last Post: 03-28-2016, 12:53 PM
  5. How can I pair my S7 to my Mitsubishi Outlander?
    Last Post: 03-28-2016, 12:52 PM
