erasat
Yeah I did it at Walgreens, never popped up so I have been trying since and still nothing between the two cards I have loaded on there. Thanks though
If you have used it already and you can see the transaction posted under the Card on Samsung Pay, go to More on the Samsung Pay app and click Events and select the $30 offers and once you see it on the screen, click More details, it should verify that you have made the purchase and brings you the option to redeem your offer. I did something similar with one of my phones when my wife cleared the offer notification instead of redeem it, after a while I realized that this process brings it back.
It should work if you can see the transaction posted on the card on the APP, if you don't see it, then it won't work as that means that as far as Samsung Pay is concerned, you haven't used it yet, then you should talk to your back and explains the issue.
