04-03-2016 01:08 AM
39 12
tools
  1. felloffthetruck's Avatar
    Forgot all about the $30. gift card deal with Samsung Pay first use on S7 and was wondering if it's still available?
    Has anyone collected the $30. gift card recently?
    03-28-2016 09:50 AM
  2. DuCeNuKeM's Avatar
    Offer is still valid until the 31st.
    03-28-2016 09:53 AM
  3. felloffthetruck's Avatar
    https://uploads.tapatalk-cdn.com/2016...785f3d9ed3.jpg
    Yes, I saw that on my phone. Does "Out of Supply" mean it's still valid and working?
    03-28-2016 10:00 AM
  4. jmm22's Avatar
    It doesn't say that for the $30 promo.
    03-28-2016 10:03 AM
  5. DuCeNuKeM's Avatar
    The "out of supply" section was for the free wireless charger. That promotion is already done.
    03-28-2016 10:07 AM
  6. Almeuit's Avatar
    This. If you use Samsung pay before the 31st you will get a free $30 gift card (almost instantly).
    03-28-2016 12:44 PM
  7. killspy6's Avatar
    Could I use samsung pay with a gift card to get the gift card? Like buy a best buy gift card, add it to samsung pay. Then use samsung pay with BB gift card. Will I get the reward? My bank currently won't use SP
    I'm in USA
    03-28-2016 04:00 PM
  8. Almeuit's Avatar
    I'm in USA
    I don't know if that would work. I think they want you to add a card and use it (hence them trying to entice us to use it) .
    03-28-2016 04:06 PM
  9. DuCeNuKeM's Avatar
    Using a gift card will not make you eligible for the promo. You will need to add a supported bank card and actually use it once.
    03-28-2016 04:59 PM
  10. felloffthetruck's Avatar
    OK, How do you get the card? Do they email it to you or does it just pop up on your phone right away?
    03-28-2016 09:18 PM
  11. Gdwheel's Avatar
    It shows up in your Samsung Pay wallet.
    03-28-2016 09:46 PM
  12. natetrain247's Avatar
    You can claim the card in the Samsung pay wallet or use the code they send via email. They are all electronic codes. Not actual cards. I got 2 $30 ebay codes (me and my wifes phone) and was easy.
    Link a card to samsung pay, use it even for something that costs $1 at a store and you'll get the notice to claim a gift card of your choice right after the transaction goes through.
    03-28-2016 10:28 PM
  13. worldspy99's Avatar
    You get an email notification as soon as your transaction is posted. I went to a local store bought something for 99c and used Samsung Pay and voila....good luck.
    03-29-2016 04:47 PM
  14. techiegirl's Avatar
    I used Samsung Pay for a purchase (Walgreen) and never received a notification offering the $30 gift card. I did get the wireless charger when I registered the card.
    03-29-2016 07:00 PM
  15. Almeuit's Avatar
    That is why -- You already claimed a free gift before. This is one for first time users of Samsung Pay.
    Aquila and goober84 like this.
    03-30-2016 10:07 AM
  16. popkurn611's Avatar
    I have endlessly tried to get the gift card with 2 different cards and nothing happens after I make the purchase. Both are Wells Fargo credit cards. Is it worth calling Samsung since this deal ends tomorrow, or is that a waste a time and they won't manually get me a gift card?
    03-30-2016 11:56 AM
  17. Almeuit's Avatar
    Was this your first ever purchase with Samsung Pay?
    03-30-2016 12:02 PM
  18. popkurn611's Avatar
    Yes
    03-30-2016 12:03 PM
  19. Almeuit's Avatar
    Yes
    Hm weird. It should just pop up right away .. I am not sure if Samsung will issue it manually. They should but.. Companies sadly don't always do what they should.
    03-30-2016 12:06 PM
  20. popkurn611's Avatar
    Yeah I did it at Walgreens, never popped up so I have been trying since and still nothing between the two cards I have loaded on there. Thanks though
    03-30-2016 12:19 PM
  21. erasat's Avatar
    If you have used it already and you can see the transaction posted under the Card on Samsung Pay, go to More on the Samsung Pay app and click Events and select the $30 offers and once you see it on the screen, click More details, it should verify that you have made the purchase and brings you the option to redeem your offer. I did something similar with one of my phones when my wife cleared the offer notification instead of redeem it, after a while I realized that this process brings it back.
    It should work if you can see the transaction posted on the card on the APP, if you don't see it, then it won't work as that means that as far as Samsung Pay is concerned, you haven't used it yet, then you should talk to your back and explains the issue.
    03-30-2016 02:59 PM
  22. popkurn611's Avatar
    So I looked on my online banking and the purchase posted to my credit card but under the Samsung pay app when I click the card it says no transactions found.
    03-30-2016 03:22 PM
  23. felloffthetruck's Avatar
    Used it yesterday and it worked just fine.
    03-30-2016 03:24 PM
  24. LdotAdot13's Avatar
    Used it today at the gas station and it worked fine. $30 best buy gift card !
    Sent from Sir Cletus Sexy IV.
    (S7 Edge Titanium)
    03-30-2016 04:02 PM
  25. techiegirl's Avatar
    I did get the gift card. It's just I totally missed the pop up. I went back to settings, events just now and I was able to redeem the gift card.
    03-30-2016 04:20 PM
39 12
  1. Keeping phone case on while using Gear VR
    By popengchan in forum VR Headsets
    Last Post: 04-04-2016, 02:54 PM
  2. notification sounds stop working after awhile...
    By Tex_Norseman in forum LG G4
    Last Post: 03-30-2016, 02:10 PM
  3. How do I delete the Google Play app forever from my phone
    Last Post: 03-28-2016, 10:00 AM
  4. Moved apps to SD card now they show up as "uninstalled"
    Last Post: 03-28-2016, 09:05 AM
  5. Where is my the mic for voice text on the s7 droid? Samsung.
    Last Post: 03-28-2016, 09:00 AM
