When I turn Doze on, I go to settings, battery, more and select Optimize battery usage. I then select Apps not optimized, select All Apps which then turns all apps to "On". I then hit the arrow to return to battery. I now exit settings. This now should turn Doze on for all apps, correct?
My issue is my battery life is still suspect, so I go back and repeat the above, and when I select Optimize battery usage, all of the apps are turned off.
Is this normal? I would think they would stay in the on position until I make a change to turn them off.
Can someone let me know if I am doing this correctly? Do I have a software issue?
Thanks for your help.
