1. AC Question's Avatar
    i reset my phone and now it requires my password before it would let me use my fingerprint. i tried locating it unfortunately my wifi was turned off
    03-28-2016 11:26 PM
  2. mhinc's Avatar
    I have to ask, you've had this phone for what? 2 weeks maybe? How can you forget your password in that time frame?
    You are going to have to bring it to your provider or an Authorized Samsung Dealer with photo ID to reset it
    bandofbrothers2112 likes this.
    03-28-2016 11:51 PM
  3. Leonard Ayala's Avatar
    : I forgot my password for my Samsung S7 Edge, how can I get back into my phone?
    11-20-2016 10:39 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Are you talking about your lockscreen password?
    11-21-2016 12:09 AM
  5. bandofbrothers2112's Avatar
    These Security Protocols are in place for a very good reason.
    Circumventing them isn't something I'm prepared to help too much with.
    Please speak with Samsung Support.
    11-21-2016 12:59 AM
  6. socarwolverine's Avatar
    Have you tried going to a computer and logging onto Android device manager? From there you can try and lock your phone, it should ask you to input a new code, put in something that you'll remember then try and unlock your phone. I know it works on one of my previous phones, but I've never tried it on my Edge.
    11-22-2016 10:28 AM
  7. KupKrazy's Avatar
    I think the only option you have is to wipe your phone by either booting into recovery mode or wiping it through the Samsung Find My Mobile site. If you are not the rightful owner of the phone, you should return it.
    11-22-2016 12:53 PM
  8. jbjtkbw007's Avatar
    I think wiping isn't an option as the password also helps with theft and the bad guys doing the same thing and then having a phone to use. I may be wrong on this, but with my LG G3, and using the McAfee, even after a wipe, it STILL prompts me for a password to do anything. Obviously, that's a 3rd party product, but that was 2 gens ago. I would think newer Android devices would have something like that built in.
    11-22-2016 01:54 PM
  9. B. Diddy's Avatar
    I would second the suggestion of trying Samsung's Find My Mobile. You can supposedly remove or reset your password remotely: Find My Mobile | Mobile Services | APPS | SAMSUNG UK
    11-22-2016 06:01 PM
  1. Samsung Gear VR Promotion
    By MisterEd51 in forum Samsung Galaxy S7 Cases & Accessories
    Last Post: 03-29-2016, 01:01 PM
  2. First time charging take long hours in SAMSUNG J7?
    By Sajith Jayawardhana in forum Batteries
    Last Post: 03-28-2016, 11:13 PM
  3. Text recovery on samsung note 5
    Last Post: 03-28-2016, 11:05 PM
  4. Samsung Galaxy Note 10.1 Problem on Factory Reset
    By Darvlaskie in forum Samsung Galaxy Note 10.1
    Last Post: 03-28-2016, 11:02 PM
  5. Replies: 0
    Last Post: 03-28-2016, 10:51 PM
