1. AC Question's Avatar
    Anytime I connect to a wifi point, my galaxy s7 edge phone stops getting any sort of Internet. This is on multiple wifi connections (work, home, gas, Starbucks, etc.) So I don't believe it is a router issue. Also, all of my other devices at home that are connected to wifi don't have this problem. Also, I've tried to reset my network settings and turned off smart switch as were advised for this problem with the s5. Anyone have a similar problem and/or fix?
    03-29-2016 02:15 PM
  2. H3aTeRzz's Avatar
    Hello & Welcome to the Android Central Forums, Certainly will try to get you sorted out!
    1. Did you recently upgrade your Android Version?
    2. Was it working, and just all of a sudden stopped?
    3. Did you download a 3rd party app recently that corresponds with the timing of the issues?
    Thanks!
    Chris
    03-29-2016 02:23 PM
  3. Ajj1367's Avatar
    I had a software update on March 22, but this problem started on March 28. I had downloaded the ebates app that day, and have since uninstalled it but the problem has persisted.
    03-29-2016 03:01 PM
  4. H3aTeRzz's Avatar
    I'm sorry you are still having this issue! My suggestion, since this is a brand new device, would be to either do a full factory reset, which I do recommend after any major update by the way, or take it to the carrier where you purchased the phone and see if they can assist you. Another option would be to contact Samsung tech support, they are usually very helpful.
    03-29-2016 08:46 PM
  5. Dmak74's Avatar
    Yes I'm having similar issues as well with the s7 edge. I just thought it was my internet. It messed up my other devices connections as well. I'm still trying to figure out how to fix it. Any suggestions?
    03-30-2016 01:17 AM
  1. Replies: 1
    Last Post: 06-21-2016, 09:15 AM
  2. Could you unlock my phone?
    Last Post: 03-29-2016, 03:00 PM
  3. Replies: 1
    Last Post: 03-29-2016, 02:57 PM
  4. How do I change messages back to message +?
    Last Post: 03-29-2016, 02:07 PM
  5. Why won't my LG phone connect to my PS3?
    By AC Question in forum More LG Phones
    Last Post: 03-29-2016, 01:41 PM
