1. TheSlyph's Avatar
    Hello,
    I just upgraded to a S7 edge and received a free subscription to Spotify. I am trying to find an app or way to stream my Spotify to either a DLNA or airplay device (I have both on my wifi network) So far the options I found only work if you root your device which is not possible on my snapdragon version of the S7 edge as I understand it. AirAudio allows me to do it but uses a delayed stream from the microphone on the phone but this means I get loop back if my phone
    is in the same room as my speakers, this defeats the purpose of using my phone to control Spotify. Does anyone know of a way to accomplish spotify to dlna or airplay non rooted?
    03-29-2016 09:13 PM
  2. B. Diddy's Avatar
    Moved to the S7 edge forum.
    03-30-2016 02:37 PM
  3. GadgetGator's Avatar
    Not sure exactly what type of device you are trying to stream to but you might want to look into chrome cast audio and see if that would be a solution for you.
    04-02-2016 04:40 PM
  4. TheSlyph's Avatar
    The device is called LDA made by Livcon.
    Device:
    http://www.davecohifi.com/Assets/DNP...LDA_ForWeb.pdf
    The problem is not on the receiver. It is an issue with Spotify not having an option to cast to airplay our dlna.
    04-08-2016 10:19 PM
  5. funtax's Avatar
    Hope there will be a way to root your phone in the near future - then you can stream everything in full quality.
    But without root, I fear there's no way for you except eg. a "Gramofon"-receiver which supports Spotify Connect.
    04-27-2016 01:17 PM
  1. Replies: 11
    Last Post: 04-05-2017, 11:22 AM
  2. Google Now, voice control and bluetooth....AGAIN
    By Frank Alberta in forum Samsung Galaxy S7 edge
    Last Post: 12-05-2016, 04:47 PM
  3. Replies: 1
    Last Post: 03-30-2016, 02:39 PM
  4. Replies: 1
    Last Post: 03-30-2016, 04:44 AM
  5. why is my screen black and blanck
    Last Post: 03-29-2016, 08:50 PM
