1. Deano240's Avatar
    Hey I have the s7 edge and I've set an alarm and the sound doesn't come through its happened about 8 times now. It also has no sound on buttons and I have to restart is there any fix
    03-30-2016 01:16 AM
  2. Samuel Orris's Avatar
    Alarm sound is a different way. To setup sound for alarm increase your alarm sound.
    03-30-2016 01:55 AM
  3. dpham00's Avatar
    Are you using dnd? If so make sure to allow alarms.
    03-30-2016 02:45 AM
  4. FallenAngel1978's Avatar
    There is another thread for this http://forums.androidcentral.com/sam...-no-sound.html
    It's also happening on my phone, it's not DND, muted or anything else. I'm also finding that some phone calls don't ring and if i try to play music while it's in this state it doesn't play straight away but takes about 10 seconds to start and fades in. Restarting seems to set it right but not for long.
    My partner has an identical phone yet has no issue, we've both installed all updates, the same apps etc so i'm wondering if it's possibly hardware related.
    03-30-2016 07:57 AM
  5. Deano240's Avatar
    Hey all sounds are on no dnd just no sound on alarms
    03-30-2016 11:04 AM
  1. in notification bar but not on lock screen?
    By udnh in forum Google Nexus 6
    Last Post: 03-30-2016, 09:51 PM
  2. Why can't I download anything on my brand new Samsung Galaxy S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-30-2016, 03:33 AM
  3. Why can't I download anything on my brand new Samsung Galaxy S6?
    Last Post: 03-30-2016, 03:31 AM
  4. Why can't I download anything on my brand new Samsung Galaxy S6?
    Last Post: 03-29-2016, 11:46 PM
  5. Replies: 0
    Last Post: 03-29-2016, 11:42 PM
