1. Ward Harris's Avatar
    I purchased an S7 edge from Best Buy and paid full retail, not a monthly contract. It is probably my bad, but I assumed at that price and without a contract that the phone would be unlocked. I travel internationally a lot and needed to replace my Note 4. I am now in Africa and when I bought a sim card over here, it will not work. The phone appears to be locked! I have AT&T service in the states but did not buy the phone from them, but they did install the Sim for me as I did not have the correct size. Is it possible that AT&T "Locked" my phone when they installed my sim? If so, is there a way to unlock the phone so I can use it for the 9 months of they year when I am not in the USA?
    03-30-2016 08:35 AM
  2. felloffthetruck's Avatar
    All AT&T branded S7 phones are locked.
    Search YouTube, there are a million videos on how to unlock he phone. I believe that you will have to pay though.
    03-30-2016 08:41 AM
  3. osubass1's Avatar
    03-30-2016 08:43 AM
  4. Ward Harris's Avatar
    I think that osubass1 probably has the answer to my problem. I made the mistake of letting ATT install my new sim and they probably installed all of the ATT stuff that "locked" my phone to that carrier. I now have an $800 brick 9 months of the year!!
    That's just wrong!!!!
    03-30-2016 08:53 AM
  5. nyc's Avatar
    If it's ATT branded and you paid full retail they will send you an unlock code. You have to request it on their website.
    DuCeNuKeM and Aquila like this.
    03-30-2016 09:50 AM
  6. DuCeNuKeM's Avatar
    I requested an unlock code for my s5 after I got my s7. The s5 is paid off. There's a section on At&t's website to request codes. It took less than an hour to get the code emailed to me. You'll have to insert a non at&t simcard before it'll ask you to input the code.
    03-30-2016 09:55 AM
  7. Almeuit's Avatar
    Site here - https://www.att.com/deviceunlock
    03-30-2016 10:08 AM
  8. Lobwedgephil's Avatar
    Actually all you need to do is have At&t unlock it for you. I bought from at&t but paid full price, had them unlock it and now it is unlocked. Below is the link to request the phone unlocked, if they approve you, you get a code to enter when you insert a different sim card.
    03-30-2016 10:09 AM
  9. Ward Harris's Avatar
    This is turning into a 3 ring circus with ATT. I found the place to request the unlock (Thanks to all that posted that suggestion). I sent them all the info and got an email pretty quickly saying that my account info is not in their system! I logged into my ATT account and made sure that the info I was giving them was the same as the info in my profile and resubmitted. In about 5 minutes I once again got a message that my account info is incorrect and they are unable to unlock my phone. But I can call them on 611 for further information. I am in Africa!! I wonder if i put my att sim back in and call 611 if I will get anyone and what will that call cost?
    03-30-2016 12:11 PM
  10. Almeuit's Avatar
    I wouldn't suggest to do that. It would most likely cost a fortune.
    03-30-2016 12:46 PM
  11. Ward Harris's Avatar
    I finally go through to someone in the chat section. It took awhile for him to understand that this is not an att phone and that they locked the phone when they put in a new sim. He says he is putting in a ticket to higher support and I should get a response in a day or two.
    03-30-2016 01:07 PM
  1. Emojis in Contacts on Galaxy S7?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 11-05-2016, 11:27 AM
  2. Looking For A True Light Silver (Titanium) Minimalist Case For S7 Edge
    By PsychDoc in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 04-14-2016, 12:03 PM
  3. What Cool or Useful Features Have You Found with your S7 Edge?
    By BamaMomRollTide in forum Samsung Galaxy S7 edge
    Last Post: 04-04-2016, 12:13 AM
  4. My sm g920f needs a pin code to unlock after I factory reset can you help?
    Last Post: 03-30-2016, 07:34 AM
