1. AC Question's Avatar
    Last evening I reset the scanner using a different finger. It worked last evening. This morning it did not work, and the screen to open with my passcode is no longer available. I am locked out of the phone. Each time I try to open with fingerprint and it fails, the phone says I have to wait so many minutes before re-trying. First it was 5 minutes, then 10, then 30, and I am now waiting for the 60 minutes to complete. The screen to enter password is no longer available. I telephoned ATT and they said the only thing I can do is a factory re-set.
    03-30-2016 12:41 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! That's odd--it should be prompting you for your backup password. I'd ask AT&T to give you a replacement phone. If they can't help you, then contact Samsung directly.
    03-30-2016 12:53 PM
  1. What OS will the LG G5 have on it?
    By AC Question in forum LG G5
    Last Post: 04-01-2016, 02:40 PM
  2. Replies: 1
    Last Post: 03-30-2016, 01:03 PM
  3. Replies: 1
    Last Post: 03-30-2016, 12:55 PM
  4. Samsung Galaxy s2 i9100 Home Button not working
    By AC Question in forum Samsung Galaxy S2
    Last Post: 03-30-2016, 12:54 PM
