1. mundo472's Avatar
    I've had my gs7e since the 11th and am set up with the edge function on the right side. Today I pulled it out of my pocket and there was a scroll on the left side that seemed to be a foursquare - like suggestion for a nearby restaurant. I did something that made it disappear and I have my idea what it was.
    Any ideas?
    03-30-2016 07:00 PM
  2. itguyjax8430's Avatar
    Any ideas?
    Welcome to Android Central!
    Are you using Google now launcher or something?
    04-04-2016 09:34 AM
  3. mundo472's Avatar
    Nope, but I figured out its a "feed" and you can pick from a couple apps that do this. Foursquare is not one. It works instead of the always-on screen and is pretty cool
    04-04-2016 10:57 AM
  1. S7 Edge slow to charge on Wireless charger
    By LMychajluk in forum Samsung Galaxy S7 edge
    Last Post: 10-20-2016, 11:08 AM
  2. S7 Edge / 2016 GMC Intellilink / Android Auto
    By jeepin2001 in forum Samsung Galaxy S7 edge
    Last Post: 04-16-2016, 04:53 PM
  3. Replies: 5
    Last Post: 03-31-2016, 08:37 AM
  4. How can I get the music I have on my S7 Edge to set as a ringtone?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-30-2016, 03:42 PM
  5. Fingerprint sensor on Galaxy 7 Edge does not work, how can I fix it?
    Last Post: 03-30-2016, 12:53 PM
