11-27-2018 07:25 PM
88 ... 234
tools
  1. Aiuspaktyn's Avatar
    Try Pixel Fixer from PlayStore
    01-25-2017 10:11 AM
  2. ZOHEB SYED's Avatar
    Another victim... It goes away if you apply light pressure just under the UNG below the speaker.
    Attachment 223956Attachment 223957Attachment 223958
    Hi..my pink line also dissappeard when i pressed under the samsung logo..thanks for the tip..jus wanted to know whether the lines appeared again or I have to sent it for repairs..pls lemme know..๐Ÿ˜Š
    02-07-2017 11:55 AM
  3. dm3ready's Avatar
    So, after about 3-4 months of tolerating this PINK line down the right side of my screen I finally tried to get AT&T to do something about it under my 12 month warranty. I didn't realize that AT&T got rid of their Repair Centers...at least in my area, so the company-owned store told me to call AT&T Warranty service. Additionally, they told me to do a factory reset to see if it would fix it. So I did that this morning...the factory reset didn't cure anything. So I called and they are shipping me another phone, a refurb, I presume, with a 90 day warranty...they did recognize that it is a Known Issue without a resolution...but on occasion, they said, a factory reset does fix it.
    03-02-2017 02:47 PM
  4. vishalrckz's Avatar
    I've faced the same problem, did the problem get solved?
    03-13-2017 04:58 AM
  5. dm3ready's Avatar
    The solution for me was a warranty exchange for another S7 Edge.
    03-14-2017 08:57 AM
  6. Bwils4's Avatar
    I have the S6 Edge that is doing the same thing. I am out of warranty though. Has anyone had Samsung do the repair out of warranty? Was there an additional cost?
    03-25-2017 01:02 AM
  7. Nel_B's Avatar
    Thanks dude, this has been annoying me all day and your comment worked! ๐Ÿ˜Š
    03-26-2017 03:38 PM
  8. turtlez86's Avatar
    Almost on the same spot as mine!!!
    08-07-2017 11:38 AM
  9. turtlez86's Avatar
    I have the purple/pink line that comes and goes depending upon pressure around the G of Samsung. I do not have any magnetic case whatsoever.
    I have a temporary fix by dialing *#0*#, and then tapping RED. The entire screen goes red and I leave it there for 4 or 5 minutes. After I exit this screen the purple line has disappeared from my screen, but it unfortunately reappears from anywhere from an hour to a few days. I have then repeated this procedure a few times.
    WAHHH THIS ACTUALLY WORK@_@
    I use put to red for 10 seconds, feeling sceptical, then put to black, saw the faint purple line, but upon exit, the purple line is gone #WhatSoceryIsThis
    Shall wait and see when it will come back as you have mentioned.
    08-07-2017 11:47 AM
  10. tsells's Avatar
    Unfortunately, it did come back for me. Maybe you'll have better results!!
    08-08-2017 10:15 PM
  11. And122's Avatar
    Aahh my cousins g5 glitched out and its like he drew on his screen with purple marker or something how do you fix
    02-26-2018 07:48 AM
  12. GoldlexusAN's Avatar
    Well stink, just paid the last payment on hubbies s7 edge and guess what has showed up?! Yup the purple line! Ugh really?
    03-31-2018 02:34 AM
  13. yeah_jono's Avatar
    OK so i kinda solved it.
    After putting up with the purple/pink line for a few months, (I dropped the phone so it was my fault) I found that there was a pressure point around the G in the logo of Samsung that when you apply pressure the line goes away.
    So i taped a vitamin to that pressure point using sticky tape. The line has gone down greatly, still there but its a very faint pink line/sometimes you cant see it at all
    Find that exact spot where that happens on your phone, then stick a pebble/something small onto it with a lot of pressure - you do lose the ability to take selfies though :P
    11-27-2018 07:25 PM
88 ... 234
  1. Ok Google screen off
    By matt3166 in forum Samsung Galaxy S7
    Last Post: 03-28-2017, 01:46 PM
  2. Why isn't my phone turning on?
    By AC Question in forum HTC Desire 626
    Last Post: 05-08-2016, 04:26 AM
  3. Replies: 2
    Last Post: 04-19-2016, 01:12 AM
  4. Sleep screen notifications
    By wcdknows in forum Samsung Galaxy S6 edge
    Last Post: 03-31-2016, 08:46 AM
  5. 30 minute time out on calls?
    By AC Question in forum Nexus 5X
    Last Post: 03-31-2016, 03:52 AM
