1. Ryanpdx's Avatar
    I'm an xfinity customer, and I use the complimentary xfinity wifi Hotspots when I'm not at home. Unfortunately it's not nearly as fast as my home network. I can't find a way in any of the settings to prioritize what network my phone connects to, and have to switch to my at home wifi after being away.
    03-31-2016 04:48 AM
  2. lammy8's Avatar
    Your phone should automatically connect to your home network when you get back, provided your WiFi is on
    03-31-2016 11:04 AM
  3. Ryanpdx's Avatar
    I wish that were the case, unfortunately it stays connected to the xfinity wifi.
    03-31-2016 11:51 AM
  4. DrGiggleFr1tz's Avatar
    I have the same issue and I haven't been able to figure anything out. Even I tell it to forget the network it seems to only forget it for a certain amount of time.
    Pretty annoying that I have to switch networks every time I walk into my house.
    03-31-2016 02:47 PM
  5. beagle82's Avatar
    It used to be an option in older versions of Android. Now you will probably have to try an app from the play store. There is an app called WiFi prioritizer. Or you could do it with the Tasker app which could be a bit trickier.
    03-31-2016 03:15 PM
  1. How do I enable mock locations on the Galaxy S7?
    By Single spaceplusanumb3r in forum Samsung Galaxy S7
    Last Post: 07-18-2016, 08:26 PM
  2. Is there an Android app that will crop photos?
    By AC Question in forum Android Apps
    Last Post: 04-06-2016, 07:38 PM
  3. Replies: 2
    Last Post: 03-31-2016, 04:28 AM
  4. How do I transfer my images to my SD card?
    Last Post: 03-31-2016, 04:16 AM
  5. How do I download updates without having an email?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-31-2016, 04:05 AM
