1. scorpiodsu's Avatar
    Hey guys, was wondering if anyone has an answer to this. I have play music set to use my SD card as storage. However it still only using the internal storage. Does anyone know why? It's always been set that way an never to internal but can't get it to save accordingly.
    Could this be an issue with this version of Android or this device? I saw it did that before but it didn't bother me as much. Bothers me now lol.
    Oh and apologies if this topic has already been talked about here.
    Attached Thumbnails Play music using device storage-7440.jpg   Play music using device storage-7441.jpg
    03-31-2016 08:44 AM
  2. makaroni's Avatar
    I've always had to move the audio files manually from internal storage to my SD card. Downloaded files are automatically saved to internal storage because you don't have to option to choose a destination folder. Just check em all and move em to a folder on your SD card and you'll be able to access em easily in play music. That's your best bet
    03-31-2016 10:18 AM
  3. scorpiodsu's Avatar
    Thanks but play music doesn't work like that. It doesn't store music on your device as separate individual audio files so you aren't able to just select file and cut and paste. It basically caches everything as one large file. This is why in the app you have to pick where you want that file to be stored. Thanks again though.
    03-31-2016 12:13 PM
  4. scorpiodsu's Avatar
    Actually what I have noticed is the play app is taking up space on both the internal and external storage. If I drill into the internal storage the app has 8.96GB of data (the rest was cache). Then I look at my SD card storage and the usage is, you guessed it 8.96GB. So I wanted to test and I cleared the data on the internal storage and it also wiped it from the external too. I google and saw that others saw similar things but no solutions. Guess I'll just try to forget about it for now.
    03-31-2016 01:11 PM
  5. Danny Long2's Avatar
    Hi did you ever fix this ? I have the same issue on my GS7 and it means I am nearly out of internal memory
    05-27-2016 03:42 AM
  6. David Rosen's Avatar
    Pretty sure it can't be done. I made another thread recently about how useless SD cards are for Android apps. Transferring files from a computer sure, but the only app I know of that actually uses the SD the way you'd hope is the camera.
    05-27-2016 09:46 AM
  7. Andrew Richards4's Avatar
    Pretty sure it can't be done. I made another thread recently about how useless SD cards are for Android apps. Transferring files from a computer sure, but the only app I knmow of that actually uses the SD the way you'd hope is the camera.
    Hi guys! I may be too late, or you already figured this out but:
    I just installed a 64gb card into my S7, and had the same issue with a couple apps - they would let me select external storage as the download point, but would not actually download/move any files to the SD card
    UNTIL
    I popped into the App Info menu for each app, went into Permissions, and turned off, then back on, Storage Permissions.
    Fixed it for me!
    Availablepublicly likes this.
    09-13-2016 11:04 AM
  8. David Rosen's Avatar
    UNTIL
    Fixed it for me!
    Interesting fix... Not seeing a change yet though... Did you have to reboot or erase the downloaded music and redownload it or something for it to work? Because just simply turning off then back on permissions doesn't seem to be making anything happen with the 2gb of downloaded thru Spotify music I have.
    09-22-2016 03:15 PM
  9. PhillipDDresser's Avatar
    UNTIL
    Fixed it for me!
    Thanks a lot for this post! Almost compromised my phone's speed by making my SD card adoptable storage. Then I saw this. Worked for me, but I had to leave my Storage Permission turned off. After turning it off I went back into Google Play Music app settings and my external storage was available as an option. So relieved!
    11-27-2016 11:48 PM
  10. PhillipDDresser's Avatar
    Try leaving the permission off. Then open your music app settings. There should now be an option to select external storage instead of internal.
    11-27-2016 11:58 PM
  11. seclinix's Avatar
    Just came across this trying to find a solution for myself so you have probably found the answer, but thought I'd share anyway as I didn't find any satisfactory answers so played around on my S7 to find solution.
    I dragged and dropped half my music from my computer to internal storage and half to sd card on my S7 so as not to use all my internal memory space, then found couldn't play from sd card, until I accidentally opened Google play (I had installed VLC as my preference) and skipped the paying ads as I want a free app, coming to the menu where I clicked on downloaded only, it highlighted music library, I selected a song, hit the shuffle all button, and hey presto all my songs were playing from both internal storage and sd card.
    Plan on moving all my internal storage songs to the sd card now via the same drag and drop method via my computer (easiest way I've found).
    02-17-2017 02:56 PM
  1. Replies: 1
    Last Post: 04-04-2016, 09:53 AM
  2. Phone unencrypted and forcing me to use a password
    By CrimsonRonin in forum General Help and How To
    Last Post: 03-31-2016, 05:41 PM
  3. Why can't I purchase Music on Google Play Store?
    By AC Question in forum Google Play Store
    Last Post: 03-31-2016, 10:49 AM
  4. how do i use custom mp3 as notification alert or message alert?
    By jianrong in forum Samsung Galaxy S7 edge
    Last Post: 03-31-2016, 08:02 AM
  5. How do you redeem Google Play credit, once registered?
    By aaarhoades in forum Google Play Store
    Last Post: 03-31-2016, 05:07 AM
