1. tstolz's Avatar
    Has anyone figured out exactly what packages need to be enabled to allow Oculus to run correctly? I've disabled most of those mentioned in this post:
    http://forums.androidcentral.com/sam...n-s7-edge.html
    The problem I'm having is only when installing or updating Oculus software. The app or game will download via the Oculus app, but it fails to install. The quick workaround has been to just enable all packages to allow the install, then re-import the XML file to get back to where I was. If anyone's figured out exactly what packages need to be running though, that'd be great.
    And no, I'm not ditching Package Enabler Pro, not after going from 2.5 hours of SOT and maybe 13-14 hours of total time on to 4+ hours of SOT and 24+ hours of total time on after installing PE.
    03-31-2016 09:15 AM
  2. DuCeNuKeM's Avatar
    Make sure that all Gear VR are not disabled.
    03-31-2016 09:38 AM
  3. tstolz's Avatar
    No, I have those all enabled. Still no dice.
    03-31-2016 10:29 AM
  4. DuCeNuKeM's Avatar
    I'm not sure what you disabled but here is my disabled packages xml for you to compare.
    https://drive.google.com/file/d/0B-K...p=docslist_api
    03-31-2016 02:26 PM
  5. Abner Paredes's Avatar
    I also have a problem with my gear vr oculus.. happened after i used package disabler pro to use the vr headset with other apps..
    04-13-2016 11:43 AM
  6. Shinigami Mai's Avatar
    I had issues with my gear vr when i first got it could not get stuff to download or uupdate after a long while of research i found out you need the facebook app enabled and you have to run it atleast once for it to update somthing then run your vr let it update then disable Facebook again and it will work fine i dont use Facebook so it was the first to get disabled .
    04-13-2016 09:09 PM
  7. tstolz's Avatar
    Bingo, this was it. Awesome, and thanks for sharing.
    04-13-2016 11:46 PM
  8. B. Diddy's Avatar
    See response in your other thread: http://forums.androidcentral.com/sam...d-problem.html
    04-14-2016 03:50 AM
  1. Replies: 4
    Last Post: 03-31-2016, 07:56 PM
  2. Replies: 1
    Last Post: 03-31-2016, 10:41 AM
  3. How to fix the invalid package and missing scatter error?
    Last Post: 03-31-2016, 09:35 AM
  4. What is User Dictionary app
    By saint_ariel in forum General News & Discussion
