1. AC Question's Avatar
    I got this message quite often:
    "enter PIN instead of using fingerprint recognition after restarting device to to protect fingerprints"
    After that I need to use PIN number. It looks like phone reboots itself in background.
    Also when my battery goes to level of 30ish percent and below that, it seems to happen more often and I think I saw it rebooting itself. But its not like full reboot only more like some sort of refresh. It refreshes whole screen and goes to blocked mode and when I want to unlock it I need to use PIN number because I got message I quoted earlier.
    03-31-2016 12:53 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it persist after a cache partition wipe? https://support.t-mobile.com/docs/DOC-25076. Or in Safe Mode? https://support.t-mobile.com/docs/DOC-25053. If so, then bring it back to the store and ask for an exchange (or contact Samsung for warranty repair/replacement.
    03-31-2016 04:02 PM
  3. ABOSWORTH007's Avatar
    I've definitely noticed that I have to use a pin to unlock after I restart my phone. I can't think of a single reason as to why they implemented this stupid feature. It's just annoying. I should at least be able to disable that "feature." I haven't had any issues with my phone restarting by itself though.
    03-31-2016 05:36 PM
  4. morphogen's Avatar
    me too it locked me out for 5 minutes.
    03-31-2016 09:00 PM
  5. B. Diddy's Avatar
    On the Nexus 6P, with fingerprint enabled, I have to enter my pattern unlock when cold booting.
    04-01-2016 01:38 AM
  6. MartinMPL's Avatar
    It's a Marshmallow "feature" extra security I guess...
    As for the OP's problem, it doesn't sound right. Try the cache wipe as already suggested and see where you are.
    makaroni likes this.
    04-01-2016 02:50 AM
  7. ABOSWORTH007's Avatar
    Well, it's a stupid feature. It's right up there with that stupid Bluetooth pop up and the volume warning pop up.
    04-01-2016 07:12 AM
  8. jamjestrysiek's Avatar
    Hi
    I just signed in
    Yesterday I restored phone to default setting and installed everything from scratch, but at the end of a day things started to be dodgy again and today from the morning phone was doing same thing. I had to use PIN code quite few time, same like I saw this alert again few times.
    I cleared cache and I'll keep an eye on how phone will react and let you know did it helped or not.
    04-02-2016 10:53 AM
  9. meyerweb#CB's Avatar
    Hi
    I just signed in
    If it's still doing it, boot the phone into safe mode and see if it's happening. If not, it's probably one or more of your apps causing it.
    04-02-2016 03:15 PM
  10. Kwanele Ntshagase's Avatar
    Yeah maybe it is in safe mode or try restarting the fingerprint recognition and new pin then reboot device
    04-02-2016 03:41 PM
  11. rnich120's Avatar
    My sony Z5 used to do the same after a reboot asking for the pin first and then i could use the fingerprint after that.
    I don't really see it as a big deal.
    04-02-2016 04:19 PM
  12. jamjestrysiek's Avatar
    You see I don't reboot my phone and it still happens.
    I don't mind to do it after reboot I did, but when it happens quite a few times a day without me rebooting my phone, then I think that something is not right.
    04-03-2016 06:03 AM
  13. jamjestrysiek's Avatar
    Yesterday after cleaning cache it was better at the beginning but later it started to do it again.
    I put my phone in safe mode today and I'll see if this will help.
    I will let you know guys how it goes.
    And thanks all for your help so far
    04-03-2016 06:11 AM
  14. zaki67's Avatar
    I have the same problem after the latest update !
    04-11-2016 07:07 AM
  15. aldo82's Avatar
    I just got my edge yesterday and finding the fingerprint reader a bit unreliable despite deleting and putting the fingerprints in again several times. I was locked out for 5 minutes earlier.
    What I have found gives more success is when I press the home button to wake the screen, i then keep it pressed until it unlocks. What I was doing before is press to wake screen then just leave my finger on the home button. It sometimes works but seems more consistent keeping it pressed. Maybe more pressure gives a better reading?
    Does anyone else keep it pressed? If having problems try it and see if it helps.
    04-11-2016 08:59 AM
  16. zaki67's Avatar
    I removed screen off which caused this to happen on my nexus 6p and so far I was not asked for a pin.
    04-11-2016 10:33 AM
  17. ThrottleJohnny's Avatar
    I have found that people are continuing to use the same press point with their finger every time it asks you to apply your finger. You have to really use SEVERAL different press points from several different parts of the finger, so that it captures every possible press point. Otherwise it's going to take longer to unlock your phone.
    I have not had a single problem unlocking my phone in a timely matter.
    04-11-2016 10:50 AM
  18. aldo82's Avatar
    I mapped my entire fingerprint as far as I could in the number of reads available and still ended up having problems.
    Do you just rest your finger on the home button then rather than having to keep it pressed down?
    04-11-2016 11:24 AM
  19. jamjestrysiek's Avatar
    Just quick update.
    It turned that it was one application which caused all this problems.
    Torch which I used had this option to to have quick access on blocked screen.
    I switched it off and now everything is smooth and fast.
    No problems with fingerprint reader and no weird notifications.
    I can also use Micro SD card without any problems. The only notification about card I have after when I'll reboot my phone.
    Thanks for help all of you guys
    04-13-2016 05:16 PM
  20. Edward bell's Avatar
    There is not a scratch on the phone. It is in pristine condition. The only problem is the finger print reader which is not working. The man in the Samsung shop said that there was a crack in the home button. My wife took a picture and there is clearly no crack. They said it wasn't wear and tear it was damaged. I have only used the home button as directed by Samsung so cannot understand why he thought it was damaged. I have a cover on my phone. I haven't dropped it or used anything other than my finger. I feel annoyed that I was accused of damaging the home button but I have only used it as directed.
    12-13-2016 12:35 PM
  1. How do I add more memory on my Galaxy Note5?
    By AC Question in forum Samsung Galaxy Note 5
    Last Post: 04-08-2016, 10:10 AM
  2. S7 batter life
    By johnmcc0710 in forum Samsung Galaxy S7
    Last Post: 04-05-2016, 12:10 PM
  3. Why does my Note 5 go on auto mute when calling?
    Last Post: 03-31-2016, 04:10 PM
  4. Replies: 1
    Last Post: 03-31-2016, 04:07 PM
  5. How can I play my YouTube Video slower on my Android?
    By AC Question in forum Android Apps
    Last Post: 03-31-2016, 04:05 PM
