1. mango1228's Avatar
    I have had my device since launch it has frozen for a few seconds and then reboots randomly. But 2 days ago my phone has done it 2 to 3 times now a day.
    any ideas as to why... Or is there something wrong with my device
    04-01-2016 03:33 AM
  2. jeetu4444's Avatar
    It's a software bug...wait till samsung gets a fix...
    Posted via My Awesome Lumia 950 ds red and gold or LG G4 or surface pro 4
    04-01-2016 05:58 AM
  3. sydneycooper1979's Avatar
    I personally would take it to your carrier and see if they will replace it.
    04-01-2016 06:14 AM
  4. Asylum House's Avatar
    Did it happen after you install some app?
    04-01-2016 06:18 AM
  5. mango1228's Avatar
    Happens randomly. Like in this app. Sometimes in internet explorer. Hasn't happened today yet....
    04-01-2016 09:51 AM
  6. zipro's Avatar
    Try formatting your SD card and make sure you don't out the card in your computer's card reader, instead use MTP and a cable.
    04-01-2016 10:38 AM
  7. mango1228's Avatar
    Thanks will try that
    04-01-2016 10:40 AM
  8. dan lif's Avatar
    same thing happens with my s7 edge. Reboots only at night and usually just once but its consistent. Last 2 days it rebooted with less then 2 percent battery. Not sure whether to return it or stick with it and wait for sammy to fix it.
    04-08-2016 11:45 PM
  9. lammy8's Avatar
    Had it happen twice so far to me. Every Android device I've had has done this at some point or other. Don't know the cause yet
    04-10-2016 02:17 AM
  1. Replies: 1
    Last Post: 05-01-2016, 08:01 PM
  2. Hello everybody. I have a moto g2 phone with android marshmallow.
    By G Sisir Varma in forum Android 6.0 Marshmallow
    Last Post: 04-10-2016, 01:24 PM
  3. How do I set and check data usage on my Panasonic Eluga Icon?
    Last Post: 04-01-2016, 06:56 AM
  4. Galaxy Tab S2 T715 International Features and Compatibility
    Last Post: 04-01-2016, 03:17 AM
  5. Replies: 0
    Last Post: 04-01-2016, 02:22 AM
