1. bren5666's Avatar
    Went and took a look at the S7 Edge today . Loved the looks and feel of the phone.Only issur I had was I kept accidently activating the edge panels, I honestly don't think it's a feature I would use much, so is there a way to turn the panels off? Would a case help? I know some will say to get an S7 instead but I've been spoiled by bigger screen phones and don't think I'd be happy.
    04-01-2016 07:13 AM
  2. sydneycooper1979's Avatar
    You can disable the panels. You can also change the size of the panel and where it is located.
    04-01-2016 07:15 AM
  3. bsteppuhn's Avatar
    I noticed I do think touch it more with a case on. You do get used to how you hold it. I love the edge panels
    04-01-2016 11:27 AM
  4. makaroni's Avatar
    The edged screen, edge panels, and it's functionality is kind of why you would even purchase the phone other than a bigger battery. There are other phones with expandable memory that you could choose. Some purchase it just for the looks but.... If you want to disable the edge panels, then just go for the S7 in my opinion.
    04-01-2016 02:31 PM
  5. recDNA's Avatar
    You said why. S7 too small and has a small battery.
    04-01-2016 02:49 PM
  6. jianrong's Avatar
    Sure. I disable mine too
    khayman9 likes this.
    04-03-2016 11:52 AM
  7. khayman9's Avatar
    By all means
    04-03-2016 12:22 PM
  8. scott_0's Avatar
    yup, mine is disabled, got the edge for the larger screen and battery
    lydia_che likes this.
    04-03-2016 04:27 PM
  1. Replies: 1
    Last Post: 06-01-2016, 07:48 AM
  2. One afternoon with my new S7 Edge... my thoughts and follow ups!
    By JF2014 in forum Samsung Galaxy S7 edge
    Last Post: 04-20-2016, 03:16 PM
  3. How do I add music from my pc to a Samsung S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 04-05-2016, 07:02 AM
  4. S7 Edge Default Alarm Snoozing itself?
    By hesketh7085 in forum Samsung Galaxy S7 edge
    Last Post: 04-02-2016, 01:07 PM
  5. AT&T. Free 48" Smart TV with S7/Edge
    By ironass in forum Samsung Galaxy S7
    Last Post: 04-01-2016, 09:23 PM
