So does it move all app data to sd card combining it with internal storage ? Or does it only move some data and it's not really worth it? Thanks.
It's a complicated question to answer. It's worth it if you need more storage for apps.
But does it move the entire app to the sd storage if you make the entire adaptable storage %100? If you move games to storage does it affect game play? Thanks !
It depends on the app. Some will allow everything to be moved, some won't. I have not personally had game play issues, but I have seen load times get just a small bit longer.
And it does show up as being stored on the sd card even when you use a file manager?
I think that would depend on the File Manager being updated to properly deal with the new storage schemes in Marshmallow. So I don't know the exact answer, other than you shouldn't be moving app data with a file manager in Marshmallow.
That would depend on the file manager I think.No I don't mean moving it using an file manager but just the mere fact of seeing the app located in the sd card using it.
I rarely use them so I have no suggestions.Which file manager would you suggest?
ES File Explorer is talked about a lot and seems popular but I can't speak to functionality with Marshmallow.
Your assertion that the storages are merged and become "one lump" is not necessarily true.Adoptable storage allows you to "merge" internal and external storage. So if you have 32GB internal and 200 GB external you now have 232GB total Internal storage. The system and all apps see it as one big chunk of memory. You can, as I understand it, allocate all or a part of you external storage to be combined with the internal.
There is a major problem here. Once merged you cannot remove the SD card and just insert a new one. The data and apps will be stored across both the internal and external memory. In some devices if you replace the card or remove and reinsert it the device will reformat the SD card.
This is one of the reasons Samsung opted not to use Adoptable storage. Can you imagine the calls when someone loses all their apps and data because they removed the card?
Also, the over all speed of memory would be limited to the slower of the two. A slow SD card could then slow down the whole system, in theory.
I would have rathered that Samsung made it available via a developer option. Those that understand it could activate it and those that don't could do so at their own risk.
Es file explorer, Astro, and solid Explorer can read sd card but cannot write to sd card. The only file browser that I have been able to write to sd card was the stock my files app.I rarely use them so I have no suggestions.
Es file explorer and solid Explorer can read sd card but cannot write to sd card. The only file browser that I have been able to write to sd card was the stock my files app.
Does burst mode work for you? I'm just curious because that's what I couldn't get to work when I had it enabledIt depends on the app. Some will allow everything to be moved, some won't. I have not personally had game play issues, but I have seen load times get just a small bit longer.
Hey jaycemiskel, I also have adoptable storage, enabled via adb. Burst mode doesn't work for me also, it just stalls there with the counter stuck at 0. I can't even exit the app except from the recent tab on the the left(s7). That doesn't even work sometimes and I have to restart the phone. Also, my phone runs just a bit slower even with Samsung 64gb evo+Does burst mode work for you? I'm just curious because that's what I couldn't get to work when I had it enabled
