1. AC Question's Avatar
    Will the S7 Edge support 700 mhz?
    04-01-2016 03:56 PM
  2. bikenski's Avatar
    Which model of S7 Edge and which carrier's 700 MHZ frequency band are you concerned about?
    (Different versions of phones support different LTE bands, and carriers use different bands in the 700 MHZ range, so that's not a straight forward question to answer.)
    Here's a link showing the FCC filing, which includes the supported LTE bands for the most common models sold in the US:
    04-01-2016 05:03 PM
  3. Rukbat's Avatar
    From what I can see, the international version covers bands 12 and 17 (both on 700 MHz). I can't seem to find frequency lists for any other versions. Phonearena lists 8 GSM versions, and the differences are usually in the frequencies supported. GSMArena just lists "LTE" - That's about as useful as saying "large" when describing a particular elephant.
    xocomaox likes this.
    04-01-2016 05:07 PM
  4. dpham00's Avatar
    You can look at the sticky which tells you which usa lte bands are supported by usa models. They all support 700MHz. But not all support the same lte band.
    04-01-2016 09:13 PM
  1. Replies: 20
    Last Post: 12-19-2016, 08:40 PM
  2. Why does my Samsung S7 Edge have problem with Whatsapp, Viber and Skype?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 05-27-2016, 05:52 PM
  3. Does case type affect phone's vibrator?
    By tomatosouplabs in forum Samsung Galaxy S7
    Last Post: 04-06-2016, 08:02 AM
  4. Replies: 3
    Last Post: 04-03-2016, 05:34 PM
  5. Replies: 1
    Last Post: 04-02-2016, 01:59 AM
