Is there a way to organize the apps in folders that I create without having to do it manually?
I use Nova and there is an option for this
I use Nova as well and I don't see this option. Could you tell me where that is in Nova settings?
Try this. Open the folder, tap on the three dots bottom right and select "sort".
You could contact the apps creator and request it.Everyone are talking how to put apps in alphabetical order but the real issue will be how to get folders in alphabetical order when you're searching inside an apps ?
