Is there a way to have time and date display like always on, but on the edge display so I don't have to take phone out of case to see time? I am using nova launcher and I dont know if that would interfere.
In settings under Display, turn on Night Clock. Just set it during the hours you want it to display the time and date and it will display them in the edge panel during those hours.
This is great except when in holster is upside down. better than removing phone at work when I need the time, I guess.In settings under Display, turn on Night Clock. Just set it during the hours you want it to display the time and date and it will display them in the edge panel during those hours.
Change it to the other edge panel then and it will read in the opposite direction.This is great except when in holster is upside down. better than removing phone at work when I need the time, I guess.
do you see a way to change the night clock to the other side?Change it to the other edge panel then and it will read in the opposite direction.
