1. rdubmu's Avatar
    Hello, I have figured out how to sync my icloud reminders, calendars and email. I have not figured out how to sync my icloud notes. I have 14 days before I have to return this phone and I am seriously considering keeping it. Having my icloud notes is very important. Even if it is a one time sync that can import into another service but I would rather have it on icloud so that I can access them from my MAC and ipad.
    04-03-2016 01:39 AM
  2. Mahender Shahani's Avatar
    Do you still have your iPhone? If you do use the smart switch on your s7 and you have the option to transfer your notes. It will then be in the memo app on your s7.
    rdubmu likes this.
    04-03-2016 04:57 AM
  3. mush10's Avatar
    Have you tried setting up icloud email? I am curious if it gives you the option to sync notes. Usually you have the boxes to check: mail, calendar, contacts, notes. I haven't tried myself but may work.
    04-03-2016 06:58 AM
  4. rdubmu's Avatar
    It doesn't
    04-03-2016 10:21 AM
  5. rdubmu's Avatar
    I still do, I'll try it
    04-03-2016 10:21 AM
  1. Unlock note 5
    Last Post: 04-03-2016, 03:53 AM
  2. Replies: 0
    Last Post: 04-03-2016, 01:26 AM
  3. Replies: 0
    Last Post: 04-03-2016, 12:57 AM
  4. Replies: 0
    Last Post: 04-02-2016, 11:45 PM
  5. Which version of Google Play Services for Galaxy S7 Edge?
