1. felloffthetruck's Avatar
    Getting another S7 edge next week and was wondering if I would get a fresher/newer phone purchasing from Verizon online or in a Verizon corporate store? What you think?
    04-03-2016 11:50 AM
  2. designerge30's Avatar
    Buy it From the store and open it there also chick every thing befor you left the shop
    04-03-2016 12:10 PM
  3. felloffthetruck's Avatar
    Any other opinions on this hot topic?
    04-03-2016 12:51 PM
  4. Shadowfalx's Avatar
    Store and online will be the same. Store you can verify the device works well before leaving, but other then that both are the same.
    04-03-2016 12:55 PM
  5. recDNA's Avatar
    Stores don't even have it in stock
    04-03-2016 03:12 PM
  6. LanceAllan's Avatar
    That's what I was going to say... No stores around me have any so online would probably be easier
    Sent from my Adamantium™ S7 edge
    04-03-2016 03:23 PM
  7. felloffthetruck's Avatar
    The corporate stores around here have all three colors in stock now.
    04-03-2016 05:26 PM
  8. LanceAllan's Avatar
    Wow... Probably fresh then, I only have 2 corporate stores by me and neither had any edges
    felloffthetruck likes this.
    04-03-2016 05:30 PM
  9. lildropofsunshine's Avatar
    If you can, get it in store so you can check it out and make sure everything is in working order before you leave. Even if it's a third party store like Diamond Wireless. The 1 corporate store where I live just recently had black in stock, but no other colors...and when I got mine on Friday, some nearby Diamond Wireless had some that had just come, and an associate from the store where I live went and picked one up for me. They asked if color mattered, and I said no, and got black. I'm assuming that was all they had, but I didn't ask because my 14 days were just about up and I truly was fine with any color.
    04-03-2016 06:11 PM
  10. recDNA's Avatar
    What do you check? I mean it turns on and connects I get but it takes me 2 days to get phone set up as I like sort of... Months before really set up perfectly.
    fsfty likes this.
    04-03-2016 10:31 PM
  11. wxman2003's Avatar
    The ones at the stores are 33.6 seconds newer than the ones online.
    04-03-2016 11:06 PM
  12. felloffthetruck's Avatar
    Good, got one from the store.
    04-08-2016 01:08 PM
  1. Tap or Swipe?
    By carlarcher in forum General News & Discussion
    Last Post: 05-30-2016, 11:01 AM
  2. Replies: 1
    Last Post: 04-07-2016, 02:23 PM
  3. Why is my phone turns off its power itself???
    By Yokaimochi in forum Ask a Question
    Last Post: 04-04-2016, 03:13 AM
  4. How do I block texts from unknown number on moto g
    Last Post: 04-03-2016, 07:06 PM
