1. leonbda's Avatar
    I'm experiencing slow wlan download speed on my home wifi. While many other devices ar using maximum speed mesured by Speedtest.net (50 Mbps), S7 max is 25 Mbps.
    I have tried everything forums have to offer by now: Restarting phone, router, changing router settings including channel, switching wifi security access off, flushing phone cache, etc...
    What I have noticed is that all my devices connected are using Wi-Fi type 802.11 n, only S7 is set on type 802.11 g. I'm not sure if this may be the problem or not. I was hoping to find a way to switch wi-fi type on my phone somehow. Is this possible at all?
    Phone specifications: Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspot
    04-04-2016 03:28 AM
  2. dpham00's Avatar
    It should switch automatically. I would try moving it closer to the router.
    04-04-2016 03:29 AM
  3. leonbda's Avatar
    I was actually 2 steps away from the router the whole time through the troubleshooting, with no physical barriers. Do you still think this could be the case?
    04-04-2016 03:37 AM
  4. leonbda's Avatar
    At the end, the only thing that helped was factory reset of the router. Everything seems ok now.
    04-05-2016 02:35 AM
  1. Just gotten the Samsung Galaxy Grand Prime
    By Nakia Johnson1 in forum Samsung Galaxy Grand
    Last Post: 04-04-2016, 06:43 PM
  2. Replies: 1
    Last Post: 04-04-2016, 06:37 PM
  3. Replies: 1
    Last Post: 04-04-2016, 06:33 PM
  4. WI-FI Connection and google sync problems with S7
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-04-2016, 06:30 PM
  5. Replies: 0
    Last Post: 04-04-2016, 03:02 AM
