J jd4d Well-known member Aug 8, 2013 108 0 0 Visit site Apr 4, 2016 #1 Why does my screen stay lit up when it's been charged? Posted via the Android Central App
B. Diddy Senior Ambassador Moderator Mar 9, 2012 165,595 4,737 113 Visit site Apr 4, 2016 #2 Does this only happen while plugged in? If so, go to Settings>Developer Options, and make sure the Keep Awake option is turned off. If you don't see Developer Options, go to Settings>About Phone, and tap Build Number 7 times to activate them.
J jd4d Well-known member Aug 8, 2013 108 0 0 Visit site Apr 5, 2016 #3 Thanks a lot. That seems to have done it. Posted via the Android Central App
