1. AC Question's Avatar
    When I listen to music...not streaming, but music on my device, I use Google Play. Well it has started randomly muting songs for 10-30 seconds at a time. So I tired a few other music apps from the Play Store and I get the same results.
    No I don't have anything running in the background and I have no notifications going off at the time of the music muting...I am just so lost and confused as to why this is happening.
    Anyone have any ideas?
    Thanks!!!
    04-04-2016 12:39 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this ever happen with other sound (like while you're on a phone call)? Check the headphone jack to make sure it's clear of debris--use a can of compressed air to blow it out, or a damp toothpick to root around.
    04-04-2016 02:23 PM
  3. Hordak49's Avatar
    It only happens with the music apps..and has only started in the last day or two.
    headphone jack is clean and clear!
    04-04-2016 02:40 PM
  4. DrGiggleFr1tz's Avatar
    Bad headphones maybe? Have you tried it without headphones?
    04-04-2016 03:11 PM
  5. Hordak49's Avatar
    This is without headphones
    04-04-2016 03:29 PM
  6. Hordak49's Avatar
    should point out that headphones work fine as does bluetooth...it is just when I try to listen from the phone's speaker
    04-04-2016 04:43 PM
  7. B. Diddy's Avatar
    It might be a faulty headphone jack, though. If it's intermittently thinking that headphones are plugged in, that might cause the sound to disappear from the speaker (since the phone thinks headphones are plugged in). You wouldn't notice this with actual headphones plugged in, or on Bluetooth.
    Try wiping the cache partition as a general troubleshooting step: https://support.t-mobile.com/docs/DOC-24999
    04-04-2016 07:58 PM
  8. HrVanker's Avatar
    This has not helped me, with the same problem. Any other ideas?
    05-17-2016 09:24 PM
  9. B. Diddy's Avatar
    Welcome to Android Central! Does it happen in Safe Mode? https://support.t-mobile.com/docs/DOC-25053. You obviously wouldn't be able to test out a 3rd party music player in Safe Mode, so use the stock Music app.
    05-17-2016 11:06 PM
  10. jnegrin881's Avatar
    I just read on another thread to install "soundabout" app. I did it and yahoo, it works great now. Just set media to speaker and everything else leave on default.
    05-30-2016 07:53 PM
  1. Replies: 8
    Last Post: 08-07-2018, 04:58 PM
  2. My samsung s7 screen is black
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-06-2016, 01:40 AM
  3. Play Music app.
    By Bob4seven in forum Samsung Galaxy S7 edge
    Last Post: 04-04-2016, 07:57 PM
  4. Replies: 1
    Last Post: 04-04-2016, 12:37 PM
  5. I can not install apps in my new tablet? continue
    Last Post: 04-04-2016, 12:34 PM
