1. bullittmustang's Avatar
    They seem to have changed the percentage function. I've had the s4, s5, s6 edge and now the s7 edge. They all worked fine, now this one has changed. Try this 200-10%=
    It doesn't work!
    04-04-2016 12:48 PM
  2. sinfoman's Avatar
    I got 180 when I did that. Maybe there's some update I have that you don't?
    04-04-2016 01:40 PM
  3. VetteVert's Avatar
    I get 199.9. I noticed this as well
    04-04-2016 01:46 PM
  4. bullittmustang's Avatar
    I did the newest update. I have the AT&T version.
    04-04-2016 02:16 PM
  5. Alanhd's Avatar
    This was discussed in another thread.
    http://forums.androidcentral.com/sam...ml#post5076110
    04-04-2016 02:20 PM
  6. marlin29311's Avatar
    200-10% = 199.9. 10% = .1. That's correct math. Was this supposed to work a different way?
    04-04-2016 02:24 PM
  7. NexusGirlX's Avatar
    On my S7 Edge, I get 199.9. On my Note 5 running Lollipop, I get 180.
    04-04-2016 02:30 PM
  8. bullittmustang's Avatar
    Yes. Every other calculator I have used, works a different way.
    04-04-2016 02:31 PM
  9. sfld's Avatar
    Yes when you put 200 - 10% it is supposed to make 10% into 20, so the math should equal 180
    04-04-2016 02:32 PM
  10. sfld's Avatar
    How does the google calc that was just recently posted to the play store act?
    04-04-2016 02:34 PM
  11. marlin29311's Avatar
    Every other android calculator, or real calculator? I just downloaded Google Calculator, and noticed that it operates in the way that you mention. However, any real calculator (ie, graphing, financial, scientific etc) will not operate in this fashion - nor would programs like Microsoft Excel, etc.
    04-04-2016 02:37 PM
  12. marlin29311's Avatar
    But basic Math order of operations says no. 10% is technically .1 in a numerical base. If you want to take 10% of 200, you should be doing 200 - (200*.10) to get your answer of 180. Or you take in the inverse way of seeking 90% of 200, or 200*.9 = 180. But basic math will stipulate that percentages are properly translated into their decimal equivalent for mathematical computation.
    04-04-2016 02:39 PM
  13. bullittmustang's Avatar
    Every other Galaxy I have owed has worked differently than the S7.
    04-04-2016 02:45 PM
  14. marlin29311's Avatar
    I would suggest to anyone who has issues with the S7 built in calculator not operating like a tip calculator should just download the Google Calculator from the play store as it will operate the way you all want it to.
    04-04-2016 03:05 PM
  15. bullittmustang's Avatar
    Samsung has updated the calculator app to function the way it used to!
    04-28-2016 08:52 PM
  16. t11rmh's Avatar
    OK that is better. No point in them being overly smart on this when other calculators work the usual way.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    04-28-2016 10:00 PM
  1. Wireless Charging Question
    By brts96 in forum Motorola Droid Turbo 2
    Last Post: 04-30-2016, 04:01 PM
  2. Replies: 4
    Last Post: 04-15-2016, 02:42 PM
  3. Question about photos on SD card
    By louzer in forum Samsung Galaxy S7 edge
    Last Post: 04-10-2016, 04:39 PM
  4. Bluetooth and location accuracy question
    By mlrz24 in forum Samsung Galaxy S6
    Last Post: 04-04-2016, 09:09 PM
  5. Display Question
    By jd4d in forum Samsung Galaxy S7 edge
    Last Post: 04-04-2016, 07:11 PM
