Camera Quick Launch notification
adelcastillo78
197
5
Ok, this is very annoying. It started happening after today's update (P8). Every time I double press the screen to take a quick picture, I get this notification which defeats the "quick launch" feature.2068.jpg
Ok, this is very annoying. It started happening after today's update (P8). Every time I double press the screen to take a quick picture, I get this notification which defeats the "quick launch" feature.View attachment 223476
Yeah, absurd! Mine just opens and that's it. Try fiddling somewhere in the settings, maybe there's some there that will stop this useless notification.
How did you set the camera to a screen double tap?
I turned on home button double tap, which works well. For me Nova launcher locks screen with double tap.
My Verizon version has done it from the start. But it's about 50% of the time.
I am having this issue also. For the first 8 hours of owning the phone there was no such notification, but not it statted happening out of nowhere.
I also had this issue but have just realised that it only happens in low light so my belief is that this is a feature to stop you accidentally opening the camera while it's in your pocket because if you don't confirm (press ok) it closes the camera.
noroldie
