1. AC Question's Avatar
    Hi All, i bought a samsung s7 edge last month and as i read how amazing its new features is i am now looking on its camera pro mode. i search the net and it they said that i could find it when i press the 'mode' on my camera app. i did it but there's no
    'pro' button there. pls help. should i activate it first like the game launcher?
    my s7 edge model is SM-G935FD
    04-05-2016 04:25 AM
  2. flintlock's Avatar
    On mine there is in the camera app the word "mode" on the left bottom corner. When you press that a whole table of things pop up. Pro mode is top right.
    04-06-2016 07:08 PM
  3. Base_UK's Avatar
    As Flintlock said, it should be am option in Mode. If not, you should also have a download menu under mode, see if you need to install it through that (but it really should already be there)
    04-06-2016 07:55 PM
  4. Bechoril's Avatar
    Hi guys.
    I need your help. I have the same problem as described on the top of the thread. I have no pro mode and no download option. I suspect that i have some weird kernel version. Unfortunatelly there is no option of attaching screenshots.
    Any solutions?
    11-06-2016 12:09 PM
  5. Deke218's Avatar
    Open the camera and swipe the screen to the right.
    pbear8118 likes this.
    11-06-2016 03:15 PM
  6. meatloafa's Avatar
    i have a new edge 7 (25/12/2016) on the camera screen I only get a auto icon and a panorama icon can't get it into the pro mode that I use all the time on my edge 6+
    12-26-2016 08:03 PM
  7. chanchan05's Avatar
    Go to settings>Applications>Default Applications>Home>set it to anything except Easy Home.
    12-27-2016 10:49 AM
  8. Mian Shah's Avatar
    GO LEFT
    CLICK VIRTUAL SHOT
    IN THE TOP LEFT CLICK THE TURN CAMERA BUTTON(MAKE SURE ITS ON THE BACK CAMERA)
    THEN GO LEFT AND U WILL SEE PRO MODE
    it doesn't work in selfie mode tho
    Hope it helps it worked for me
    04-11-2018 05:15 PM
  1. Stop Note 4 from turning on screen when moved
    By TaoEntropy in forum Samsung Galaxy Note 4
    Last Post: 07-08-2016, 09:17 AM
  2. Replies: 8
    Last Post: 04-06-2016, 06:46 PM
  3. Can I change the bootloader on Nexus Android Phones?
    By AC Question in forum Misc. Android Phones
    Last Post: 04-05-2016, 05:40 AM
  4. Why does my data connection automatic turn on?
    Last Post: 04-05-2016, 05:09 AM
  5. Video modes???
    By khyos94 in forum HTC One M8
    Last Post: 04-05-2016, 01:28 AM
