04-26-2016 06:08 PM
28 12
tools
  1. skribbles505's Avatar
    Plenty are and will be available but all will fail.
    It's just the nature of the beast.
    As far as I can tell most fail due to cases pressing against the sides where they adhere. Spigen guarantees their protective film won't have this issue with their cases, although they do not produce a glass protector. If they can solve the issue with the film though, solving the issue with the glass protectors should be doable. I'm still curious as to why they don't do a glass one though.
    04-20-2016 02:58 PM
  2. louzer's Avatar
    How do you know this?
    I emailed them and they told me.
    Posted via the Android Central App on the edge
    04-26-2016 05:39 PM
  3. TMavC5's Avatar
    If you plan on using this as protection on screen. You will break it if you plan using case.
    04-26-2016 06:08 PM
28 12
  1. Replies: 3
    Last Post: 08-22-2016, 12:35 AM
  2. Replies: 1
    Last Post: 07-29-2016, 12:39 PM
  3. Why is there a problem communicating with Google servers?
    Last Post: 05-01-2016, 09:04 PM
  4. Why does my S7 put calls on hold?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-05-2016, 09:22 AM
  5. Coming soon??? NSFW
    By athomas917 in forum VR Headsets
    Last Post: 04-05-2016, 08:00 AM
