Save big + get 3 months free! Sign up for ExpressVPN today
04-26-2016 06:08 PM
28 12
tools
  1. AC Question's Avatar
    I bought my son Samsung S7 Edge and he is so happy to have it. My fear is he always drops his phone and S7 Edge screen is very delicate. So I want to have it protected by installing tempered glass on S7 Edge. Right now, we put only the rubber screen protector which is very expensive but cannot protect as much as the tempered glass.
    04-05-2016 09:16 AM
  2. TMavC5's Avatar
    I'm using Zagg HD and its great.
    Samsung Galaxy S7 Accessories | ZAGG
    04-05-2016 11:08 AM
  3. clintw22's Avatar
    There isn't any good tempered glass screen protectors out as of right now but Zagg is supposedly coming out with one soon but who knows when.
    04-05-2016 11:19 AM
  4. Justin Hammond's Avatar
    Do you have a case on it too? I also have the HD screen protector for the s7 edge, but the Otterbox Symmetry case occasionally peels the edge of the screen protector up, so I have to take the case off and rub the edges back down. I was just wondering if anyone else is having this problem or would have any suggestions on other cases?
    04-12-2016 08:56 AM
  5. felloffthetruck's Avatar
    Plenty are and will be available but all will fail.
    It's just the nature of the beast.
    04-12-2016 09:33 AM
  6. LGalaxyGirl's Avatar
    Tech Armor, which I've had the most success with, is coming out with one - I just don't know when.
    04-12-2016 11:53 AM
  7. csleverette's Avatar
    Depending on what case is on your device, you may want to take a look at one from GPEL.
    https://www.gpelstore.com/collection...nt=18266578631
    04-12-2016 12:01 PM
  8. lterry913's Avatar
    Someone mentioned that this only adheres at the top and bottom. Is this true? Have you tried it? I am very intersted but would like opinions.
    04-12-2016 01:40 PM
  9. felloffthetruck's Avatar
    Correct, none of these stick to the actual display area of the screen. Only the top, bottom and thin sides. The second you put a case on your phone they pop right off.
    lterry913 likes this.
    04-12-2016 02:05 PM
  10. csleverette's Avatar
    I have tried it. I think it sticks top and bottom and sides. It didn't fit well with my case however. I kind of knew that was a possibility going into it as many don't fit with cases so far. I wanted to try at least.
    04-12-2016 02:24 PM
  11. Loozpatienz's Avatar
    GPEL has at least one minimalist case coming out later this month that is made to fit their glass screen protector. They are both on Amazon for about $40. The glass is on the way and the case ships later this month. Trying to be extra careful with it until then.
    04-12-2016 06:02 PM
  12. Loozpatienz's Avatar
    I should mention it is a "clear" case. I am trying to keep the look of the phone for those times that I feel protection is needed. Here it is on their site, but Amazon sells it for $15. https://www.gpelstore.com/collection...case-pre-order
    04-12-2016 06:06 PM
  13. ShinyTop's Avatar
    The GPEL has very mixed reviews on Amazon. Biggest issue appears to be a loss of sensitivity to touch.
    04-12-2016 09:32 PM
  14. lostsoul2's Avatar
    I never got that far.. I just mailed it back @ my cost yesterday. thing was flimsy and broke on the corner when making adjustments. it has a think adhesive strips on the sides and it makes that glass on glass crunch. Its "suppose" to be corning gorilla glass, if it is I think it might be first gen or something. Seeing how it broke so easily I would not trust it even if it was on looking and working great.
    People need to save their time and money and get get a good case, good film protector and INSURANCE.. If your planing on having this phone for 2 years get it. I wish I didnt have to learn the hard way
    04-13-2016 12:33 PM
  15. csleverette's Avatar
    I posted earlier about trying this one out and ultimately got rid of it for this exact reason. Went into the grocery freezer section and touch when crazy. I knew then it had to go.
    04-16-2016 06:26 PM
  16. felloffthetruck's Avatar
    The new ZAGG curved glass looks promising if they ever bring it to market. Looks like it might stick to the actual display.
    clintw22 and oks10 like this.
    04-16-2016 08:38 PM
  17. jeetu4444's Avatar
    Here is my s7 edge with tempered glass and cover
    Attachment 224970[ATTACH]null[/ATTACH]
    Posted via my Awesome Lumia 950 , Beautiful S7 Edge Gold or Surface pro 4
    Attached Thumbnails Will there be available tempered glass for S7 edge soon?-1138.jpg
    04-18-2016 10:42 AM
  18. felloffthetruck's Avatar
    All I see is the back^^^^
    04-18-2016 11:05 AM
  19. joebloggs13's Avatar
    I have the Spigen curved crystal film on mine. The install wasn't too bad, but am pretty sure it won't give me the same protection as a true glass screen protector. Hoping for something decent in the near future.
    04-18-2016 02:47 PM
  20. jeetu4444's Avatar
    Here is the front Will there be available tempered glass for S7 edge soon?-1137.jpg
    04-19-2016 05:23 AM
  21. lady of the lake's Avatar
    Here is the front Click image for larger version.
    What cover and case are you using?
    My Spectacular Samsung Galaxy S7Edge
    04-19-2016 10:14 AM
  22. louzer's Avatar
    If you buy a Zagg film protector, they will credit you the difference when their glass protector comes out.
    Posted via the Android Central App on the edge
    04-19-2016 10:28 AM
  23. felloffthetruck's Avatar
    I don't believe the Zagg glass for the S7 edge will ever come to market. Just what I think.
    04-19-2016 11:02 AM
  24. clintw22's Avatar
    How do you know this?
    04-19-2016 11:14 AM
  25. skribbles505's Avatar
    I would get the Samsung protection plan from them directly. Better than some of the Asurion/Carrier options.
    04-20-2016 02:54 PM
28 12
  1. Replies: 3
    Last Post: 08-22-2016, 12:35 AM
  2. Replies: 1
    Last Post: 07-29-2016, 12:39 PM
  3. Why is there a problem communicating with Google servers?
    Last Post: 05-01-2016, 09:04 PM
  4. Why does my S7 put calls on hold?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 04-05-2016, 09:22 AM
  5. Coming soon??? NSFW
    By athomas917 in forum VR & AR Lounge
    Last Post: 04-05-2016, 08:00 AM
