1. AC Question's Avatar
    When I turn my S7 edge on the Sd card "for transferring photos and media"notification comes up. What can I do to eliminate this?
    04-06-2016 02:42 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this only happen when you first power the phone on from a powered off state? If so, that's normal. It's simply notifying you that an SD card is inserted and ready for use. You should be able to swipe that notification away.
    04-06-2016 06:07 PM
  3. xocomaox's Avatar
    You can't stop it from coming up just once, I have tried many different things.
    04-06-2016 06:20 PM
  4. dimsdale's Avatar
    Seems many many people are having the same problem with the SD card notification re-appearing multiple times (after swiping away the first one on boot). I'm starting to think it's a sleep issue. I think when the phone sleeps or suspends a process due to inactivity it might be happening. I've done some extended file transfers over USB to the SD card and haven't seen the notification during the transfers. So I don't think it's a hardware problem.
    04-06-2016 08:12 PM
  5. felloffthetruck's Avatar
    Welcome to the club.
    04-06-2016 08:16 PM
  6. Ying Hang's Avatar
    Don't know if the issue has been solved, yet. I have the same or similar issue with my S7. I'd tried many ways and couldn't get rid of it. My was appeared on home screen. I tapped on it, held, and moved/dragged down. There were three buttons appeared, one of which was REMOVE. I clicked on it, and the notification disappeared. Hope this help. It may come back if you restart the phone!
    04-14-2016 06:53 AM
  1. Can't download /update apps from google play app store
    Last Post: 07-20-2016, 07:00 AM
  2. Can't share bug report?
    By Nathaniel Graham in forum Samsung Galaxy Note 5
    Last Post: 04-11-2016, 08:41 AM
  3. Custom Ringtones / Notifications for contact groups....
    By telrod11 in forum Moto X Pure Edition
    Last Post: 04-08-2016, 05:59 AM
  4. Replies: 1
    Last Post: 04-06-2016, 03:03 PM
  5. Replies: 1
    Last Post: 04-06-2016, 02:56 PM
