1. AC Question's Avatar
    So I'm really liking the new touchwiz launcher - the one which comes standard with the phone. However, I want to change my icons using an icon pack. Is there any way I can do this without using a launcher? Or get a launcher but retain the look & feel of the touchwiz launcher?
    04-06-2016 05:05 PM
  2. B. Diddy's Avatar
    Moved to the S7 edge forum.
    04-06-2016 05:20 PM
  3. edubb256's Avatar
    You can use an app like Awesome Icons along with an icon pack of choice to change the icons individuals. This only applies to icons on the home screen.
    04-06-2016 05:53 PM
  4. Javier P's Avatar
    +1 for Awesome icons. Take a look here for more information about this app.
    Hate an app icon? Here's how to change it http://www.androidcentral.com/hate-a...-how-change-it
    04-06-2016 06:20 PM
  5. Cakefish's Avatar
    Theme store will allow you to change the icons and more.
    04-06-2016 07:05 PM
  6. lyneld's Avatar
    Theme Store looks like its exactly what I'm looking for - but I can't find the option to change icons. Do i need to create a new theme somehow and just replace the icons?
    04-07-2016 09:03 AM
  7. kami8586's Avatar
    Theres an app that will let you, i just can't remember which one.
    S7 Edge Titantium
    04-07-2016 01:56 PM
  8. amar1975's Avatar
    You can use icon changer application.
    (link removed by Moderator)
    It make a clon and you can put it only on main pages not in drawer
    07-30-2016 12:18 PM
  9. dpham00's Avatar
    Mod Note, please do not post links to apk downloads.
    There are icon change apps in the play store, here is one
    07-30-2016 01:23 PM
  1. T-Mobile S7 - turning off wifi auto-connect?
    By ydocody in forum Samsung Galaxy S7
    Last Post: 04-10-2016, 12:57 PM
  2. Replies: 8
    Last Post: 04-08-2016, 01:22 PM
  3. Samsung Galaxy A7 headphones not working (Volume Control buttons)
    By AC Question in forum More Samsung Phones
    Last Post: 04-06-2016, 05:52 PM
  4. How can I find out my userid and password for Samsung Galaxy Core Prime?
    By AC Question in forum Samsung Galaxy Core Prime
    Last Post: 04-06-2016, 05:39 PM
