1. nocaldawg's Avatar
    So I am a current Note 5 user and generally like it with the exception of battery life. Have been reading the threads the last couple weeks and see a comment here and there comparing the Note 5 and S7 Edge. Just getting mixed input on the battery. Any input would be appreciated.
    04-06-2016 10:46 PM
  2. designerge30's Avatar
    You have to check your charger currant;-)
    04-06-2016 11:52 PM
  3. nocaldawg's Avatar
    Ha ha.....
    04-07-2016 12:26 AM
  4. laestrella's Avatar
    I currently have both phones and I couldn't be happier with my s7 edge battery. I was never satisfied with the Note 5 battery life. I think the s7e wins because the battery is bigger and marshmallow helps because of doze. I actually use my phone to make lots of calls. I can usually get 4 to 5 hours of calls along with 3 or 4 hours of screen time on a single charge. The Note 5 could never do that.
    04-07-2016 06:44 AM
  5. Mike-Mike's Avatar
    I didn't have a Note 5, but I had the Note 2, 3, and 4, and now I have the S7 Edge and it's the best Samsung device of all time. Battery life is far superior to any previous Galaxy
    fishman33185 likes this.
    04-07-2016 09:13 AM
  6. MizWylie's Avatar
    I think the S7E smokes the Note 5. Because it's newer, has the giant battery, and is downright wicked fast. I came from a Nexus 6P and a Note 5. The Note 5 was a smidgen too ergonomically challenging for my tiny little hands, so I went with a 6P, which I rocked naked and handled just fine. The S7E is awesome.
    Posted from the S7E Chrome™ on Big Red
    04-07-2016 09:38 AM
  7. walsted's Avatar
    I also had the Note5 - and battery on my S7E is just killing the Note5. I really loved the Note5, but hated the battery life and switched because of that.
    On the side, I still have my iPhone 6S Plus - battery life on S7E and iPhone are more or less the same.
    04-07-2016 12:05 PM
  8. monty Stinson's Avatar
    Big difference in battery life for me comparing the Note 5 to the S7E. Missing the S pen a little and still missing the IR blaster.
    04-08-2016 02:37 PM
  9. nocaldawg's Avatar
    Thanks for all the input
    04-10-2016 07:01 PM
  1. Re: Galaxy S7 voice to text feature missing from keyboard ?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 12-20-2018, 11:47 PM
  2. Replies: 8
    Last Post: 04-09-2016, 09:48 AM
  3. Note 5 Burning Hot Charger
    By throssel in forum Samsung Galaxy Note 5
    Last Post: 04-08-2016, 02:07 PM
  4. 2.5 hours to charge from 15%, any ideas why?
    By Rick Jacobs in forum Samsung Galaxy S7
    Last Post: 04-08-2016, 11:29 AM
  5. Note 4 N910c?
    By MoxieFox in forum Samsung Galaxy Note 4
    Last Post: 04-07-2016, 03:21 PM
