1. takpro's Avatar
    Has anyone sucessfully installed and used Here Maps on the Galaxy S7 or Edge SD card? I've been trying to find out from Here for over a month. They don't seem to know.
    04-07-2016 01:47 PM
  2. ogio's Avatar
    why not install it and try moving it to the card?
    04-07-2016 01:54 PM
  3. ogio's Avatar
    ok, you got me looking at offline maps now.
    i installed HERE, but the phone doesnt give me the option to move the app to the sd card.
    04-07-2016 02:47 PM
  4. brava27's Avatar
    Why would you want to? 300mb is nothing lol
    04-07-2016 04:47 PM
  5. ogio's Avatar
    That's only for the app. Then you download maps for whatever country you want. Usa is almost 5gb
    04-07-2016 05:46 PM
  6. rdavenp3's Avatar
    You can change map storage to the SD card in the app settings.
    04-07-2016 06:01 PM
  7. mariusfilip's Avatar
    the app itself is installed on the phone, but you can get the data on the SD-card, open Here Maps, settings, select storage
    04-07-2016 07:36 PM
  8. ttriwezwu's Avatar
    There is an SD-Card and there are settings with memory, but the option save on external SD-Card is not there.
    07-07-2016 05:08 AM
  9. Kacper86's Avatar
    I have the same problem with Moto G 2nd gen. When you use sdcard as internal storage (new option since Android 6), then Here Maps doesn't see your sdcard. But I don't understand why I cannot move this app to sdcard in Settings/Applications.
    09-28-2016 01:36 AM
  10. Metatime's Avatar
    "When you use sdcard as internal storage" Yup no options to switch to that in Here maps.
    10-14-2016 01:21 PM
  11. Metatime's Avatar
    Send an email to support appsupport@here.com. I just sent my complaint about the issue
    10-14-2016 01:27 PM
  1. my do not disturb option stuck on total silence in moto g2.
    By AC Question in forum Moto G (2014)
    Last Post: 06-05-2016, 01:37 PM
  2. Why can't I get the Snapchat update on my LG G4c phone?
    By AC Question in forum Snapchat for Android
    Last Post: 04-12-2016, 06:56 AM
  3. Can I use an S4 car charger on my S7 Edge?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 04-07-2016, 03:12 PM
  4. Widgets on my Galaxy S5 not updating?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-07-2016, 12:53 PM
  5. my do not disturb option stuck on total silence in moto g2.
    Last Post: 04-07-2016, 12:47 PM
