1. AC Question's Avatar
    I have a Samsung S7 Edge. My issue is that only half the WiFi connection works. What I mean is that I can surf the Web but can't download apps or play Netflix. During the initial setup it shows that it can't connect. However, it is connected through the router (proven while talking to the router manufacturer). Does anyone know if this is a known issue with this phone?
    04-08-2016 10:56 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen on any wi-fi network, or just your home one? If it's just home, then try rebooting the router by unplugging its power for 10 seconds, then plugging back in. If that doesn't help, review this guide: http://forums.androidcentral.com/amb...-problems.html
    Another thing to try is to log into the router's settings (check the router manual to learn how), and disable IPv6.
    04-08-2016 11:03 AM
  1. Galaxy S7 - Excessive Battery Drain
    By Andy205 in forum Samsung Galaxy S7
    Last Post: 10-13-2016, 09:44 AM
  2. What is the best case for the S7 Edge?
    By AC Question in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 09-25-2016, 02:04 PM
  3. Galaxy S7 Edge serious WiFi Issues, help please?
    By catu in forum Samsung Galaxy S7 edge
    Last Post: 09-12-2016, 01:13 AM
  4. How do I uninstall or take visual voicemail off of my Galaxy S6 Edge?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 04-08-2016, 10:45 AM
