Nova Launcher Swipe Right
dyna mike
Active member
Mar 15, 2016
34
I've got Nova Launcher installed. Before I installed it, when I would swipe right to navigate to my most left home page, I would be shown news articles. Now it's changed to gmail, and I have no use for gmail. Can I change this?
dyna mike
Active member
Mar 15, 2016
34
Do you have a widget showing there? You can always just delete the widget and add the widget you want to use.
What I was trying to do is get flipboard back to the default left homepage. At the time I posted this, I didn't know it was called flipboard or I would have said that lol I'm still learning the ropes. But I think I got it figured out now! Thanks though!
MartinMPL
378
It's not supported by Nova as far as I know.
You can set up a short cut (like swipe up) to bring up Google Now if that's what you refer to - although Touchwiz does have a Flipboard style aggregator...
My suggestion is start using Google Now, either as above or with the Google Now Launcher which has it on the left screen.
fallingOutOfLoveWfithTech
