1. brad419's Avatar
    Will it hurt to leave my S7 Edge on the wireless charger overnight or is it just like charging with a cord?
    04-08-2016 10:06 PM
  2. sydneycooper1979's Avatar
    It should be fine. That's how I charge my phone most nights and I haven't had any problems.
    brad419 likes this.
    04-08-2016 10:09 PM
  3. xocomaox's Avatar
    I wouldn't worry if it's the non-fast charger. What you don't want is the phone to be hot for a long period of time. The slow charger will create less heat.
    04-08-2016 10:46 PM
  4. jeetu4444's Avatar
    I charge my lumia 950 ds same way leave on my wireless charger whole night...charging stops once battery is full...
    I just purchased the S7 edge gold...will buy a fast charging wireless charging for it
    Posted via My Awesome Lumia 950 ds red and gold or LG G4 or surface pro 4
    04-09-2016 09:06 AM
  5. Iva_LadyDiCaprio98's Avatar
    What I usually do if I have to keep it charging overnight is turn off the fast wireless charging on the phone (go to settings-battery and you will see the toggle there) so it charges through normal speed. Gives me a piece of mind that my phone won't burn up too hot durning fast charging.
    ABOSWORTH007, brad419 and xocomaox like this.
    04-09-2016 10:45 AM
  6. Rukbat's Avatar
    Once the battery reaches 100%, wired or wireless, charging stops. The only problem with a wireless charger is that current is still being drawn from the charger, so you have 2 "problems". 1. You're paying for power that's not doing anything. It's being drawn from the charge plate, going to the phone, but not being used. And 2. some (you'll have to check yours) wireless charge plates throw off quite a bit of heat. If yours does, and the phone is sitting over that heat source for hours or days, it's bad for the battery and for a few other components. That said, I've left my phone on a wireless charge plate for days (it gets about 5° F warmer than the table it sits on) and it's had no bad effect at all, except for probably a few cents of wasted electricity.
    04-10-2016 09:40 PM
  7. ilordvader's Avatar
    My wireless Fast charge take 3hrs to charge
    is that normal ?
    04-15-2016 03:13 AM
  1. Response from Samsung regarding IR blaster removal.
    By droidntn in forum Samsung Galaxy Note 4
    Last Post: 11-30-2016, 12:26 PM
  2. Mini Review - Official Samsung Leather Cover
    By map1978 in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 10-31-2016, 03:25 PM
  3. Samsung Gear S2 - Using Bluetooth earpiece for phone calls
    Last Post: 04-14-2016, 07:03 AM
  4. Can i reverse the update to my Samsung 6?
    Last Post: 04-10-2016, 09:49 PM
  5. What is a good replacement for a Samsung Galaxy Note 10.1 2014 Edition?
    By Grumpy Old Tom in forum General Help and How To
    Last Post: 04-08-2016, 09:40 PM
