11-01-2017 05:56 PM
41 12
tools
  1. mattmartin15's Avatar
    yes, you can put 2 sims in the slot instead of a sim and an SD card. if you do then you have a choice of sim 1 or sim 2 to send message. so that explains the blue box
    05-05-2016 10:53 PM
  2. NishaBarrett's Avatar
    I know this is late but I have a GS7 on the Sprint network. I was texting my bf when I noticed a little 1 pop up next to my texts. So connecting pieces, I assume it's from being in chat mode. I noticed that right under his contact name in the thread it told me when he was replying back. And after he replied I noticed the little 1 gone.
    09-07-2016 06:56 AM
  3. steezytech's Avatar
    no idea how to fix it but g'day mate. where bouts ya from?
    09-07-2016 07:25 AM
  4. Hope1986's Avatar
    This is not the case because I am with a different provider to sprint.
    I tend to find that it only happens to a particular friend though.
    09-12-2016 02:46 AM
  5. Sean Fuji's Avatar
    I think it's defaulting to the first number in your phone number. if you don't have a set username or whatever it defaults to that 1. so if you're phone number is +1 123-456-7890, it's going to display a 1. I THINK.
    09-28-2016 11:12 AM
  6. JOC2016's Avatar
    If you have a dual sim phone you can give both sims a different name and also represent them with a different icon, you can set preferences for outgoing text messages, mobile data and calls, but you need to set mobile data to the sim that sits deepest into the phone, the bottom number one socket since this is the only location with 3g capability - the other location is only 2g calls only. When you text message - send or receive the requisite icon appears next to the messages so you know which sim it has come from. If you don't set an icon I could well imagine that a number 1 or 2 might equally appear. I hope this helps - I am a FD owner too.
    09-28-2016 12:54 PM
  7. AmanDUH1031's Avatar
    I know this thread is a few months old but I figured I would chime in anyway... so I got my Galaxy S7 in June, since then I haven't been able to use the enhanced messaging at all because most of my friends have iPhones & those that do have android don't have new enough phones... well I met someone yesterday & we exchanged numbers, when he text me I noticed that it was an enhanced message & when I send him a message I see the little number 1 next to my messages until he reads them & then it disappears. So I'm thinking that it's a read receipt but I'm not sure why it is a number 1... has anyone else figured this out yet?
    11-11-2016 06:58 PM
  8. Golfdriver97's Avatar
    It may be the number of unread messages. I'm curious if you sent 2 in rapid succession if that number would reflect that.
    11-11-2016 07:29 PM
  9. meganloree's Avatar
    I have the dual sim version (ordered the wrong one oops! ) and only use 1 sim in it. For me the little '1' next to the message definitely relates to which SIM it is coming/going from. In Sim card manager you can update the icon used - by changing the icon all the little '1' signs changed to the new icon I chose. i haven't got a memory card in the other slot yet - maybe when I do that annoying little icon will go away......
    11-21-2016 11:11 PM
  10. Vladimir 1979's Avatar
    For my galaxy a5, after I installed an sd card, nothing changed, I still see the sim icon in SMS threads
    01-05-2017 02:45 AM
  11. geekeys's Avatar
    that's ridiculous that they don't make an option to turn that SIM icon off.
    01-10-2017 09:18 PM
  12. vineeenmanarang's Avatar
    If by any chance your boyfriend has either the Galaxy Note 4 or later models (S6 edge and the later Note models) then you both have Enhanced messaging turned on. The number 1 appears beside a message when the recipient haven't read it yet and disappears when it's read.
    02-06-2017 09:10 AM
  13. Chris Green81's Avatar
    It doesn't appear to be because of unread messages because it's still there after receiving a response and there were three separate texts from me all with the little "1" before the response that remained after.
    02-15-2017 04:22 PM
  14. Atmavidya's Avatar
    I have the same issue on note 8. I have only one sim card.
    09-19-2017 10:48 AM
  15. Mildred Janet Jones's Avatar
    This little blue 1 appears next to most of my messages. It looks like a sim card. I can't seem to figure out how to get rid of it. Or why it is there. Does anyone know?
    Do you have secure folder?
    09-19-2017 07:16 PM
  16. lleonillo's Avatar
    I also noticed the same "1" on my Samsung s7 texts. While in my wife's Samsung A7, i noticed a number "2" in all text messages...
    11-01-2017 05:56 PM
41 12
  1. Replies: 3
    Last Post: 04-13-2016, 08:24 AM
  2. Replies: 3
    Last Post: 04-13-2016, 08:22 AM
  3. The latest update removed the mic on my text and email
    Last Post: 04-13-2016, 08:17 AM
  4. How delete misc files from my android tablet.??
    Last Post: 04-12-2016, 12:07 AM
  5. Can my photo album be recovered? Galaxy S4
    By AC Question in forum Samsung Galaxy S4
    Last Post: 04-10-2016, 05:56 PM
