Originally Posted by
mr3flowers Ok...so I have the same issue but I believe that I have found the solution. The issue revolves around the automatic wireless searching system in the unit. I noticed that every time my Bluetooth turned off or disconnected , the wifi I had disabled turned on.
I turned all of the automatic wifi searching features under advanced....everything off ...and that solved the problem. This suggests a software issue.
Try it and let me know
Can you explain a little clearer where to locate this because I am unable to!
I had no problems connecting for a long time and just recently it started to disconnect,reconnect, disconnect. So annoying!
FWIW, I drive a 2016 Audi Q5. I realized that it wasn't my car when I picked up a loaner and it did the same thing. I truly thought it was my car until I got the loaner and then decided to search on Google for this issue and lo and behold here you all are, facing the same darn thing. SMH
