1. tasaran's Avatar
    So i have a question. My daughter put the sim card tray tool into the mic hole at the top. Do you think it made any damage to waterproof/ damaged the mic? She put it about half a cm or something.
    04-09-2016 04:37 PM
  2. anon(19981)'s Avatar
    I don't think so, but you can test it by taking a video and put your finger over the bottom microphone hole and make some noise. If it sounds normal when you play the video back than you know that there is no issue. Good luck.
    04-09-2016 07:00 PM
  3. bullittmustang's Avatar
    You can test it by downloading Samsung's voice recorder app from the Galaxy app store. Then record something in interview mode. I read that the mic hole is L shaped, so you probably didn't do damaged. I know "someone" that did the same thing one night.
    04-10-2016 10:56 AM
  1. where can i buy a sim card for a smartwatch
    By AC Question in forum Smartwatches (Non Android Wear / Wear OS)
    Last Post: 02-07-2018, 11:43 PM
  2. Camera stuck in selfie mode
    By cbreze in forum Moto X
    Last Post: 07-12-2016, 12:48 AM
  3. Replies: 7
    Last Post: 04-22-2016, 02:52 AM
  4. Micro SD cards
    By Mike Dee1 in forum LG G5
    Last Post: 04-10-2016, 09:05 PM
  5. Replies: 1
    Last Post: 04-09-2016, 10:23 PM
