1. AC Question's Avatar
    Recently purchased an S7 Edge. Using Straight Talk with an AT&T sim. Everything works as it should with the exception of all apps. I am not able to download or open any apps unless I am connected to wifi. I have checked settings to ensure updates over both wifi and cell data is enabled. I have also ensured the restrict background data is turned off. My mobile data is on and my enhanced LTE services is on. I do not have any data limits set. Under the data tab when I open an app, the view app settings button is greyed out and will not let me access it. I have talked to the Samsung folks at Best Buy and they are puzzled. Before I take this phone back, I wanted to see if anyone here can help. Thanks.
    04-10-2016 09:31 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Make sure the APN settings are correct: Straight Talk ::: Bring Your Own Phone ::: Keep everything you love
    04-10-2016 03:21 PM
  3. ABOSWORTH007's Avatar
    Wife connection... Lol
    jneusch likes this.
    04-10-2016 03:58 PM
  1. Facebook app saying can't connect
    By neptunesgirl in forum Samsung Galaxy S6
    Last Post: 09-26-2016, 12:51 PM
  2. Replies: 21
    Last Post: 05-02-2016, 07:15 AM
  3. Check Internet Connection & Try Again - Note 5 Marshmallow
    By bpittam in forum Legacy Android & Other OS's
    Last Post: 04-11-2016, 10:04 AM
  4. Replies: 1
    Last Post: 04-10-2016, 03:22 PM
  5. Replies: 3
    Last Post: 04-10-2016, 10:21 AM
