1. Zendroid1's Avatar
    Edge users, do you find yourself accidentally having edge presses register on your phone? If so, are you using a case or not? I'm having some issues with my palm / hand registering and launching things a bit too often for my liking. I know the software update is supposed to help with this but is this an issue for anyone else?
    I'm using a thin TPU case.
    04-11-2016 02:38 PM
  2. gnuser's Avatar
    Samsung has rolledout an update...Hurry up and wait depending on your carrier.
    04-11-2016 02:46 PM
  3. Keith Molloy's Avatar
    I was getting this pretty bad when using the keyboard. Whenever i would reach to hit a key on the far side of the keyboard i was accidentally touching the side closest to my palm! I have since bought a case and the issue is ALOT better
    04-11-2016 03:05 PM
  4. meyerweb#CB's Avatar
    Even a very thin case will largely eliminate this problem.
    xocomaox likes this.
    04-12-2016 07:30 PM
  5. xocomaox's Avatar
    This!
    I have two cases now, one is thinner than the other (both pretty thin... Liquid Crystal and UltraHybrid by Spigen) and they both cut down almost 100% of the issues I had with how I held the phone.
    04-12-2016 09:42 PM
  1. Galaxy S7 Edge edge feed not working???
    Last Post: 07-14-2016, 08:43 AM
  2. No tmobile service with unlocked Moto X play in the usa
    Last Post: 04-11-2016, 04:53 PM
  3. How to send a picture with a text message?
    By crazyamor in forum Samsung Galaxy S6
    Last Post: 04-11-2016, 02:49 PM
  4. Is AT&T Samsung Galaxy s6 compatible with T-Mobile
    Last Post: 04-11-2016, 12:52 PM
  5. Set specific tones to personalize texts with Galaxy S7
    Last Post: 04-11-2016, 10:41 AM
