1. oneformula's Avatar
    Do you use it? Should I change l disable it?
    04-12-2016 09:43 PM
  2. meyerweb#CB's Avatar
    These might help.
    [Q] What is the ANT Radio Services? | Samsung Galaxy S 4 i9500, i9505, i9505G, i9506
    http://forums.androidcentral.com/sam...-ant-apps.html
    If you don't use any ANT devices, the apps probably aren't using any cpu or battery. But I disabled the two components that can be disabled in the application manager, and haven't noticed any ill effects.
    04-13-2016 12:24 PM
  1. Have Samsung S7 Edge ANT+ ?
    By stonefox in forum Samsung Galaxy S7 edge
    Last Post: 05-19-2016, 08:21 PM
  2. Replies: 1
    Last Post: 04-12-2016, 08:02 PM
  3. Galaxy S6 with Garmin and ANT+ devices
    By hmcewen in forum Samsung Galaxy S6
    Last Post: 04-10-2016, 06:44 AM
  4. what is ANT servis
    Last Post: 02-22-2016, 12:29 PM
  5. how to stop ANT + Plugins service
    Last Post: 02-14-2016, 03:32 PM
