1. Soggly's Avatar
    Anyone have any idea what this is? It keeps draining my battery, the 10346 thing?
    04-13-2016 03:24 AM
  2. Alanhd's Avatar
    I have seen that once and I assumed it was when I was using wireless sync on Media monkey. But I could find no reference to it anywhere. I've not seen it since but I don't check every day.
    04-13-2016 04:03 AM
  3. Soggly's Avatar
    Yea there's just no info on it anywhere, it's strange
    04-13-2016 05:21 AM
  4. Alanhd's Avatar
    OK just did another Google search and found a reference to Uid 10346 on a Sony thread with it referencing "people app". Can't do any digging atm as I'm at work.
    04-13-2016 05:46 AM
  5. Soggly's Avatar
    It's cool, I appreciate it, would just also really appreciate if it'd stop killing my battery though lol
    04-13-2016 06:05 AM
  6. Alanhd's Avatar
    Can you do another screen grab with all showing. I will compare it against mine and see if anything obvious is missing from yours. It may just be an app not reporting the I'D right. Have you tried restart your phone and charge to 100% to reset.
    04-13-2016 06:19 AM
  7. erasat's Avatar
    I think I've seen that recently after uninstalling the Good Lock app, it seems that once the system doesn't recognize that app anymore it simply labels it like that.
    I don't know if you had the same app installed, if you did, then do clear the apps cache on the Settings-Storage options and then do a Wipe cache Partition under Recovery Mode. (look for how to enter to recovery mode).
    04-13-2016 09:18 AM
  8. Soggly's Avatar
    Nope didn't have that, it just showed up because I noticed unusual drain lol
    04-13-2016 04:42 PM
  9. lostsoul2's Avatar
    FBI looking around.?
    04-14-2016 02:15 AM
  10. MartinMPL's Avatar
    There were a few items like this when the Nexus 5x first came out and it appeared to be a way of Marshmallow displaying processes that perhaps should have been gone in an uninstall.
    Try wiping the cache from the bootloader. This may remove any stray processes if that is the cause, and no harm done if not.
    04-14-2016 02:45 AM
  1. Replies: 7
    Last Post: 04-14-2016, 01:49 PM
  2. Replies: 3
    Last Post: 04-13-2016, 10:58 PM
  3. Where is theme option on my Samsung Galaxy Note 4?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 04-13-2016, 08:07 AM
  4. Any way to get this stock watchface in blue?
    By bckrupps in forum LG Watch Urbane 2nd Edition
    Last Post: 04-12-2016, 11:56 PM
