Moving data is easy, just use either a computer or the file manager to do so. Moving apps, depends on the app (not all can be moved). For that you need to go to the Application Manager, select the app you want to move, select the STORAGE section, and if it has the option to CHANGE storage location, then it can be moved to SD card; if the option is not there, then it cannot be moved.
