1. Rumblee1's Avatar
    Well, I couldn't wait for the S7 edge. But to be truthful, im appreciating my S6 edge right now. My S7 edge keeps loosing data signal. I cant get calls, make calls and no Internet, nothing until I go to settings - Mobil networks - network mode and toggle between global and lte/cdma. Then it'll work for a while. Then off again and I have to repeat the process. I've checked all settings and they're correct. Only thing I haven't done is a factory reset. Any ideas? My S6 edge never had any issues. My only real gripe was battery life. But since marshmallow, even that is respectable now.
    04-14-2016 05:29 AM
  2. MartinMPL's Avatar
    Return it, either for replacement or not.
    04-14-2016 05:43 AM
  3. bullittmustang's Avatar
    Sounds like maybe a carrier issue. Have you called your carrier?
    04-14-2016 06:05 AM
  4. ironass's Avatar
    Which model of Galaxy S7 Edge do you have?
    04-14-2016 06:08 AM
  5. areyes163's Avatar
    Sounds like it may be defective. I would return or exchange it especially if you s6 doesn't have these issues.
    04-14-2016 07:46 AM
  6. Rumblee1's Avatar
    UPDATE - I just talked to Verizon and they had me turn on wifi/hd calling and so far it's been excellent. They're also sending me a new sim in case I still have an issue. If all fails, they'll swap out the phone.
    04-14-2016 02:25 PM
  7. jeetu4444's Avatar
    Yes lot of ppl said sim card is a problem at times...
    Posted via My Awesome Lumia 950 ds red and gold or LG G4 or surface pro 4
    04-14-2016 02:35 PM
  1. Replies: 8
    Last Post: 05-29-2016, 06:13 PM
  2. Replies: 2
    Last Post: 04-15-2016, 01:59 PM
  3. Replies: 1
    Last Post: 04-14-2016, 02:17 AM
  4. Replies: 1
    Last Post: 04-14-2016, 01:09 AM
  5. Replies: 1
    Last Post: 04-13-2016, 11:59 PM
