1. purpleparrotuk's Avatar
    Hi can anyone tell me how to disable the inbuilt samsung dialer with package disabler pro.
    I tried disabling com.android.phone but then nothing popped up when i tried to calling myself. Truecaller is set as the default.
    04-14-2016 07:12 AM
  2. H3aTeRzz's Avatar
    Hi
    I personally would not try this, regarding disabling of native apps. But....Package Disabler Pro, has some awesome support response, open up play store and scroll down to "Send Email" I needed some help a few weeks ago, and they were quick to reply and knowledgeable about my problem, solved it quickly.
    Hope this Helps!
    Chris
    04-14-2016 09:28 AM
  3. purpleparrotuk's Avatar
    Hi
    Hope this Helps!
    Chris
    Thanks. Maybe it's best to leave it alone and delete true caller. Not sure why Samsung allow you set a dialler as default when it doesn't actually work.
    H3aTeRzz likes this.
    04-14-2016 02:31 PM
  1. How long the adhesive in tempered glass last inside the packaging?
    By bogellenong in forum Nexus 6P Accessories
    Last Post: 06-08-2016, 05:30 AM
  2. How do I connect my S5 to friendcaster pro
    Last Post: 04-18-2016, 05:43 PM
  3. Replies: 1
    Last Post: 04-14-2016, 02:19 AM
  4. Replies: 0
    Last Post: 04-13-2016, 03:43 PM
  5. Replies: 1
    Last Post: 04-13-2016, 11:43 AM
