1. Josan86's Avatar
    After about a week of use the display started showing green colours in the always on screen and streaks of maroon in any whitish background. I gave the set to the service center they said it would be resolved in a day, however they are unable to do even after a week mentioning first display problem then Soc issue. As I still have the return option from the online purchase vendor, should I persist with the Samsung service center or take the device and return it to the vendor for replacement/ money back
    04-15-2016 03:03 AM
  2. chennaite's Avatar
    Kindly replace it. Don't risk yourself. The display might have damaged while manufacturing. Once it's step into the service center I think they won't replace that much easily but that depends upon the site/store. Good Luck!
    04-15-2016 06:27 AM
  3. dpham00's Avatar
    I would return it for a replacement
    04-15-2016 06:30 AM
  1. Replies: 2
    Last Post: 06-17-2016, 07:54 AM
  2. Replies: 17
    Last Post: 04-16-2016, 05:12 PM
  3. Call Screen and Lock Screen issues
    Last Post: 04-14-2016, 10:51 PM
  4. Replies: 2
    Last Post: 04-14-2016, 08:12 PM
  5. do i have a faulty device? (home button issue)
    By raptorz in forum Samsung Galaxy S7 edge
    Last Post: 04-14-2016, 07:35 PM
